Poly caps and CapAnalyzer 88A
  • Steelhack
    • May 2012
    • 24
    Ok...here is my question...I have a XBOX 360 S ripped down...It would occasionally get the red ring of death.....but when it was given to me...I could turn on..and run around menus and the internet....but I did not have a game to put it under load......so I took apart with the idea of reseating the heatsink... two poly caps near the cpu/gpu under the heatsink have a light brown leakage around their area....So I tested with Capanalyzer...and sure enough...came back bad....but then I checked the bank of 6 on other side...and they also came back bad .....I used the 88a on a LCD board..and everything worked fine.
    Is it possible that just all those poly caps are bad...yet could still fire up the XBOX...or is the lower ESR of the Polys affecting the CapAnalyzer reading?
    HACK
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Poly caps and CapAnalyzer 88A
    Not sure how the CapAnalyzer works, but it may be fooled by the low resistances of the CPU and the GPU that those caps filter. Also, polymer caps fail usually quite violently, so you would have noticed if they did. Probably aren't bad, but I need a picture of them to see. If you're really convinced there must be something wrong with the caps, then my suggestion is to remove them and test outside of circuit. Note that you will need a good soldering station to do this. A cheap unregulated iron may not be enough to remove caps from that board.
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      ... two poly caps near the cpu/gpu under the heatsink have a light brown leakage around their area ...
      I believe polymer caps do not have liquid electrolyte. So if that light brown substance is leakage from those two caps, they are electrolytic, and have a problem.
      PeteS in CA
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i have an 88a and iirc on polys and tantalums the display bargraph wraps back around on some parts.like when you squeeze the tweezers a bit harder to get a better connection.
        seen on mlcc too.
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • Blag
          Japanese 3DO with leaking caps - (nearly) full poly replacement
          by Blag
          Hi all, I've got a 1994 Japanese Panasonic 3DO with 2 leaking caps. Since all the caps are now 25 years old I decided to swap them all before more of them start to leak.
          To reduce the danger of another leakage in the future I decided to swap every possible cap with a poly cap.
          Has anyone here done that already and give me some hints?
          I found a "fitting" (voltage, uF and measurements) poly cap for all but 3 caps. The largest cap is a 6800 uF 25v cap, since there aren't any 6800er polys I'll get a high quality electrolyte one with a higher temp rating. The...
          10-26-2019, 07:59 PM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
