Capacitor Value and Measurements
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi all, ok im getting more and more knowledge from this forum and i have to say i highly appreciate about all the inputs and outputs out of this forum based on everyone's feedback about caps. Thank you very much for that. I just need to learn a bit more about caps.
    Ok example. 220uf 450v cap. Lets take from the microfarad value. Original value of the cap is 220uf, but upon using various testers and meters, it shows
    Cap - 240.8 UF
    ESR - 0.16 Ohm
    Ok so what i need to know is, the cap uf should be + or - 10% right? And if its above than that then its gone, correct? I'm not assuming, im still learning. Just need some guidance in understanding caps more deeper. So is the above reading for the cap is faulty or its in fine range?
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: Capacitor Value and Measurements
    Cap - 240.8 UF
    ESR - 0.16 Ohm
    Actually brand new capacitors very often will measure higher than its labeled value. Any electrolytic capacitor can have up to +/-20% tolerance. The capacitance value will decrease as it ages, subjected to too much heat or too much ripple current beyond its specifications. Usually if it measures way below its nominal 20% tolerance then its either aged a lot (getting too old) or already starting to fail (going bad).
    • DjKrish
      • Oct 2012
      • 354
      • SG
      20%, ok i got that So looks like the cap i stated is dying anyway.........
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Did you mean that 220uF being measured as 240.8uF? That one sounds fine, as higher is better. Only worry if the capacitor's reading measures way lower than 220uF. Here's an example of highly aged dying/failing capacitor (see attached image below) pulled out of a computer PSU. Interestingly that one does not show any external signs at all (no bulging on either top or bottom, and no leaking brown gooey).
        • mariushm
          • May 2011
          • 3799
          Capacitance is useless to determine the quality of the capacitor.
          In lots of cases, the capacitance can remain the same while the internal resistance increases a lot, or the capacitance actually drops when there's higher voltage or higher frequency going through the capacitor.
          A multimeter uses low voltage and low frequency, which is not the working conditions inside a power supply, monitor etc.
          Also, two multimeters will report different capacitance values for the same capacitor simply due to the measurement technique, current and voltage used to do the measurement, and they'll both have a +/- 5-10% error margin by default.
          You kinda need a bridge or a good LCR meter to test a capacitor completely. A minor variation in capacitance compared to what's on label doesn't mean anything.
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Which i used the ESR70 by atlas peak to measure the cap.
            • mariushm
              • May 2011
              • 3799
              They also use a low voltage to measure capacitance.
              Also, the ESR70's capacitance measurement is decoupled from the ESR measurement, as far as I know. So the capacitance is not measured with the 100kHz frequency, but rather in a separate step.
              Most cheap capacitance meters just use constant current pulses to charge the capacitor a bit, then let it discharge a bit and repeat and they use that time period and current amount to estimate the capacitance.
              Things can change when the capacitor has 12v constantly at a 30-50-70kHz frequency.
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Even if at low voltage (using the cheap capacitance meters) the capacitor measures way below its labeled capacitance, then its certainly a sign of bad capacitor. Also capacitance can change with temperature (at higher temperatures the capacitance goes up rather than down, and the ESR decreases), which is why some equipment with badcaps may behave oddly (e.g. would not function properly at cold start and needs "warming up").
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • Per Hansson
                  Motor run capacitor physical size vs voltage rating & measurements?
                  by Per Hansson
                  (TL;DR skip the first paragraph)
                  I encountered my first dead motor run capacitor at a customer this week.
                  For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                  (Unless a servo motor makes more sense that is).
                  But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                  The pump would run but sometimes trip the 10A breaker.
                  I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                  Then it could...
                  09-20-2020, 06:32 AM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                • chth96
                  How can I test non-polarized capacitor?
                  by chth96
                  I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                  I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                  And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                  I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                  06-02-2024, 07:31 PM
