Noob needs help choosing replacement caps (experts please help)
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Noob needs help choosing replacement caps (experts please help)
    I've seen quite a bit of GP caps in PSU's (on the main rails), and usually with no PI coils, or very small ones. They're usually 105C rated though, not that I would ever want to use them...
    • Stevevil
      • Jul 2013
      • 15
      • United States Of America
      um... I'm not sure but to recapitulate what I'm hearing, my choice of general purpose (regardless of the close specs) are the wrong choice for this type of circuit? It's definitely a monitor power supply. I searched for about 2 hours last night on various sites to find those listed, I'm not sure where I can find closely matching caps that aren't GP (the only other type I saw listed were "automotive" and like I asked above, I don't know what that means unless it's rated for 12v DC.)
      At this point I am really afraid to pick these out myself. I would really appreciate anyone who is willing to find me links to suitable caps (if these aren't going to work). I've had this thing disassembled for over a month and I really didn't know it would be so difficult to find the right parts. I'm pretty sure I can manage the soldering part (I've fixed some motherboards before) but I guess this is why electronic shops charge so much (for the knowledge it takes to find correct parts without a schematic). One thing I had to consider was if I could buy just one or a couple (mouser had minimum orders on some caps and so did digikey).
      I so want to get this thing fixed.
      Can anyone help?
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        The ones we picked out are good, we're talking about general purpose caps that are meant for basic circuits like a home radio or something, that are rated at 85C (don't handle heat well at all) and have very poor ripple specs. Don't worry about the capacitors we all chose for your monitor, we just got a little off topic
        • Stevevil
          • Jul 2013
          • 15
          OK, whew. Thought I put that work in and messed it up.
          I didn't even notice that one was 300 min. Yikes.
          So you feel 1.9A is close enough to the original ripple of 1.75 to not matter, I guess.
          Petes CA, you've got a ton of posts, do you also agree with my final choices (going with the 2nd on the cap with two links) and the replacement P4 helped me find?
          Man, I'll be so excited to get these ordered.
          And why does that one say Automotive? No one has told me what that designates.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            1.9A over 1.75A is better, that means it can filter more ripple than the previous capacitor without getting overloaded, and since it is rated higher, for the work it's doing it should run more cool. This is important in monitors because even though they don't use a lot of electricity, it's all passively cooled so they can be hard on parts.
            • cheapie
              null
              • Jul 2010
              • 849
              It means nothing. It's just commonly used in automotive equipment. It can still work anywhere as long as the specs are OK, which they are in this case.
              • mariushm
                • May 2011
                • 3799
                #27
                Digikey uses the "General Purpose" category as a sort of catch-all. It's not what you think it means and what we normally refer when we say general purpose capacitors.
                They just put some specific categories besides that catch-all category like "Audio" , "Automotive" and "Motor start" ...
                Sometimes the capacitors used for automotive purposes need to have additional certifications (they're more expensive) and they need to handle heat and vibrations better and those series may be able to survive better small bursts of voltage (for example spikes of 30-50v coming from alternators or whatever (i don't have a car so I don't know the exact terms).
                If you're really curious, you can just select automotive category and check the datasheets of some random capacitors ... for example some Epcos capacitor advertises up to 40g vibration protection, a Nichicon series says high reliability 1000 hours @ 150c, an UCC series says 5000h @ 125c ... so the trend for these is high temperature and vibration related stuff aparently.
                As for audio capacitors, it's a lot of marketing speak in those datasheets... don't get me started.
                • PeteS in CA
                  • Aug 2005
                  • 3583
                  • USA, Unsure of Planet
                  #28
                  Yeah, I've got the keyboard equivalent of a big mouth. Seriously, your choices, with P4's recommendations, look good.
                  PeteS in CA
                  • Stevevil
                    • Jul 2013
                    • 15
                    #29
                    Thanks for the help everyone. I just ordered my caps. I'll update this thread with my results in about a week. Fingers crossed that I don't fry anything changing em out.
                    • Stevevil
                      • Jul 2013
                      • 15
                      #30
                      Replaced the caps (6 caps took me over 2 hours to remove and replace) but I was surprised how well most of my solders went. I'm writing this using the monitor now and it's working perfectly! No artifacts, no problems!
                      Thank you so much for your help with this project. I'm so stoked to get my IZ3D working again!
                      I learned quite a bit during this process and I'll be better equipped for my next repair project (maybe I'll finally fix that cap-plagued dell sx240 I've been sitting on for 2 years).
                      Until next time my friends.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Glad to hear you got it working. Good job!
                        • withalligators
                          Looking for best replacements for Capxons, but can't find data sheets
                          by withalligators
                          Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                          1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                          1 x Capxon 1000uf35v...
                          03-25-2022, 02:30 PM
                        • ADV
                          Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                          by ADV
                          Good day everybody
                          I hope I'm posting in the right section - I am new to this awesome forum.
                          I have received an ACER Ferrari F-20" LCD Monitor to repair.
                          It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                          For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                          I opened the external 18V power supply and see no bulged capacitors...
                          11-02-2021, 09:32 AM
                        • Guest
                          A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                          by Guest
                          Hello all!
                          Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                          After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                          09-26-2024, 03:31 AM
                        • valerio_vanni
                          Choosing programmer
                          by valerio_vanni
                          https://www.badcaps.net/forum/troubl...10#post3764310
                          I come from this thread (I have to flash a SOIC-8 chip, possibly with a clamp).
                          I began searching for a CH341A, since it has low price and it's an operation that is not going to be frequent.
                          But during my search I discovered that there's often an issue with voltage, that is 5V instead of 3.3. Someone says to look at PCB colors, some other that it doesn't matter....
                          11-14-2025, 05:43 PM
                        • competition
                          Replacing capacitors in Evga PSU
                          by competition
                          I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
                          11-14-2025, 11:12 AM
