Can I use 470uF wet cap instead of 330uF solid cap?
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Well the long story short.. I asked my sister to get me some caps and the guy in the store completely misunderstood what I wanted. I asked for a 270uF 16V solid cap, he said he only had 330uF and I said OK. What I actually got was a 470uF 16V regular capacitor
    Now I'm not gonna argue over 50 cents so I'm thinking - can I just use this cap instead? I'm a bit impatient and want to fix the motherboard as soon as possible
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Re: Can I use 470uF wet cap instead of 330uF solid cap?
    It just occured to me that what I thought was a solid polymer cap, could just as well be a regular 'wet' cap. How can I be sure? It hasn't got any vents.
    • c_hegge
      • Sep 2009
      • 5219
      Do you have a picture of it? What are the markings?
      • Half-Saint
        • Jan 2010
        • 213
        • Slovenia
        The mobo is an ASUS P5KPL-AM.
        Markings on the cap:
        5K017
        270
        16V
        Link to the photos:
        https://slo-tech.com/forum/t556757/p3920019#p3920019
        • cheapie
          null
          • Jul 2010
          • 849
          5K017
          270
          16V
          Link to the photos:
          That is an Apaq polymer.
          • Half-Saint
            • Jan 2010
            • 213
            • Slovenia
            Where do I get a replacement? Everything on eBay is either from China or Hong Kong which is one and the same...
            • Koda
              • Aug 2011
              • 317
              • Macedonia
              If you can find a dead GPU or motherboard with the polymers you could salvage one.
              Guns don't solve problems. I'll take 12
              • Half-Saint
                • Jan 2010
                • 213
                • Slovenia
                Yeah just my luck.. I had two dead GPUs which I threw away two or three weeks ago
                Would this be a suitable replacement:
                http://www.ebay.de/itm/4Pcs-Solid-ca...item337b847bca
                The original question remains:
                Can you use a regular cap in place of a polymer?
                • mariushm
                  • May 2011
                  • 3799
                  No, you shouldn't use a regular electrolytic for that. 270uF 16v electrolytics will have too low ripple and too high esr.
                  Those Fujitsu polymers on eBay.de would be good.
                  • Half-Saint
                    • Jan 2010
                    • 213
                    • Slovenia
                    Thanks. I just remembered that I still have and old 775 mobo in the workshop. Maybe there's a suitable donor cap on it. If not, I'll be getting those Fujitsu caps.
                    • Half-Saint
                      • Jan 2010
                      • 213
                      • Slovenia
                      I received Fujitsu caps this morning and replaced the broken cap. The motherboard works fine
                      Thanks everyone
                      • madscientist750
                        Replacing electrolytic caps by solid caps on old motherboards
                        by madscientist750
                        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                        10-19-2025, 06:10 AM
                      • Perry Babin
                        Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                        by Perry Babin
                        I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                        This is for the primary side of a switching power supply in a car audio amplifier.
                        Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                        10-16-2025, 05:20 AM
                      • Weelcup
                        XPS 9520 not powering up. Solid orange led
                        by Weelcup
                        Hi friends
                        I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
                        I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can...
                        10-20-2025, 04:22 PM
                      • cajoeg
                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                        by cajoeg
                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                        02-10-2025, 04:01 PM
                      • dhan
                        HELP: 330uF tantalum capacitors
                        by dhan
                        Hello Everyone,
                        I'm just a bit curious or let say uncertain for these caps.
                        I have tried to replace NEC tokin 0E907 with 4 pcs of 330uF 2.5V.
                        the laptop works fine.
                        then another laptop (different laptop) came after a year, with the same issue.
                        but this time I have a different type of 330uF tantalum caps.
                        the one I've used before was 330 with small letter e on the markings.
                        e = 2.5V, but this time I have 330uF with letter d on the markings
                        d= 2.0V, right? correct me please.
                        the question is, does 4 x...
                        11-15-2020, 01:31 AM
