Can I use 470uF wet cap instead of 330uF solid cap?
    Well the long story short.. I asked my sister to get me some caps and the guy in the store completely misunderstood what I wanted. I asked for a 270uF 16V solid cap, he said he only had 330uF and I said OK. What I actually got was a 470uF 16V regular capacitor
    Now I'm not gonna argue over 50 cents so I'm thinking - can I just use this cap instead? I'm a bit impatient and want to fix the motherboard as soon as possible
    Re: Can I use 470uF wet cap instead of 330uF solid cap?
    It just occured to me that what I thought was a solid polymer cap, could just as well be a regular 'wet' cap. How can I be sure? It hasn't got any vents.
      Do you have a picture of it? What are the markings?
        The mobo is an ASUS P5KPL-AM.
        Markings on the cap:
        5K017
        270
        16V
        Link to the photos:
        https://slo-tech.com/forum/t556757/p3920019#p3920019
          5K017
          270
          16V
          Link to the photos:
          That is an Apaq polymer.
            Where do I get a replacement? Everything on eBay is either from China or Hong Kong which is one and the same...
              If you can find a dead GPU or motherboard with the polymers you could salvage one.
              Guns don't solve problems. I'll take 12
                Yeah just my luck.. I had two dead GPUs which I threw away two or three weeks ago
                Would this be a suitable replacement:
                http://www.ebay.de/itm/4Pcs-Solid-ca...item337b847bca
                The original question remains:
                Can you use a regular cap in place of a polymer?
                  No, you shouldn't use a regular electrolytic for that. 270uF 16v electrolytics will have too low ripple and too high esr.
                  Those Fujitsu polymers on eBay.de would be good.
                    Thanks. I just remembered that I still have and old 775 mobo in the workshop. Maybe there's a suitable donor cap on it. If not, I'll be getting those Fujitsu caps.
                      I received Fujitsu caps this morning and replaced the broken cap. The motherboard works fine
                      Thanks everyone
