What PC brands are safe?
  • wolch
    • Jul 2004
    I'm looking to buy an older PC for someone who just does e-mail and a bit of surfing. I'd like to get something in the range of a PII-400 to PIII-800, and you can get a PC like this for next to nothing on e-bay. It seems to me that this type of PC was made around the peak time for badcaps though.
    Any advice on what brands of PCs in the PII-400 to PIII-800 range were least affected by badcaps--or preferably, are known not to have the problem at all?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    I would really look into a 133Mhz bus PIII like an 866 or thereabouts, something with FCPGA and not Slot 1 so you could get an Intel 815 chipset which is really nice and stable although limited to 512mb ram.
    PII 400 is not really a good purchase for the future and a minimum speed for XP or 2000. 256mb ram minimum preferably for those OS. But if you are very cost conscious then look at an intel BX chipset slot 1. Not really worth it i think.
    Probably it will be best to get a mobo/proc/ram on ebay then a new but cheap case, also a new CRT and new HDD. Thereby you will get the best value but longevity from your purchase. CRT and HDD are so cheap now anyway.
    I think you are asking which brands of PC like Dell HP or whatever and not which mobos. Very difficult to answer because it depends on what mobos were inside which range. Would be best to choose a specific mobo which does not have crap caps. Intel original mobos have been quite consistent with good caps. Any body else have ideas?
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      After a bit of thought, the old dells with slot 1 used to use intel made boards. Probably had good caps on. If anybody can advise regarding the socket 370 dells, that would be useful. P4 HPs we have seen here using MSI boards with crap caps so they are a no no.
      • cook
        Good brands of run capacitor for house heat hump
        by cook
        Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
        Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
        09-13-2024, 12:53 PM
      • abhorsen
        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
        by abhorsen
        Hey guys,
        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
        07-06-2023, 10:22 AM
      • harp
        ATX brown wire sense range
        by harp
        I thinking to modify some ATX ver 1 supply, and wonder what if I connect 10k pot on 12v and center tap on brown wire? What range of 3.3v correction can to expect, or something will blow up if I close to rails, leave narrow 3.3v range?
        It is KA7500B ic, but 3v3 sense is connected to TL431, I am not sure there is any connection between.
        05-16-2024, 05:44 PM
      • Rekoo1997
        Ambient thermistor out of range
        by Rekoo1997
        dell latitude 5570
        LA-C841P
        i am check ph601
        ph602
        ph603
        ph604
        ph605
        ph1302
        all is ok and flash bios
        and didn't fix
        Can someone please tell me where to find this sensor and how to correct the problem?
        04-21-2025, 10:35 AM
      • wnlewis
        New wire for my RDE3340 Whirlpool electric range
        by wnlewis
        OK. I got the rocker switch figured out thanks to the good advice on this forum.
        Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
        This is a Whirlpool RDE3340 electric range.
        The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
        Where may I find parts...
        01-08-2025, 11:21 PM
