A7M266 16V 1200uF
  • S33K3R
    • Jun 2004
    A7M266 16V 1200uF
    I have the following motherboard - A7M266
    A cap fell of do to handling and I would like to replace it.
    The cap is a 16V 1200uF.
    My question is would a 16V 1000uF work or will it cause some sort of problem?
    Thanks all in advance
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    A 1000uF in place of a 1200uF will more than likely be OK, 1000 is borderline on the 20% tolerance of 1200. If possible, go up to 1500uF. NEVER decrease the voltage unless you know what you're doing.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • S33K3R
      • Jun 2004
      will increase have any ill affect? I believe the cap is used as a filter on the motherboard
      thank you for your advice
