Best replacement for CrapXon KF?
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Got two ADSL modems (Motorola 2210, Netopia 2240N), fulla CapXon KF caps, both had one blown (near the DC jack on the motorola, Temporarily kludged a used G-Luxon in there so I can get online), and behind the tx from the phone line on the Netopia. Any suggestions as to what to replace these with?
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: Best replacement for CrapXon KF?
    UPDATE: Ordered some Rubys from the BCN store for both modems. Only two I couldn't find were a 25uF/22V, and a 3300uF/16V (Seen plenty of 6.3v 3300s though)
    • retiredcaps
      • Apr 2010
      • 9271
      22uF 25V is here
      https://www.badcaps.net/store/produc...roducts_id=102
      What does DC voltage does the power adapter provide? If it is around 5V, you can safely use 3300uF 10V.
      --- begin sig file ---
      --- end sig file ---
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        It uses 12VDC. For the 470/16 near the DC jack I ordered a 470/25 for a little more headroom.
        I see that, but what goes there is a 22/35. (I got my #s mixed up it looks like, I meant 22uF/35V)
        • retiredcaps
          • Apr 2010
          • 9271
          If your DC adapter is outputting 12V DC, then a 22uF 25V will work fine even if the original is a 22uF 35V. Even a 22uF 16V will work fine if the 12V DC adapter is regulated. If the DC adapter is unregulated, it may run higher than 12V without a load.
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
