Best replacement for CrapXon KF?
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Got two ADSL modems (Motorola 2210, Netopia 2240N), fulla CapXon KF caps, both had one blown (near the DC jack on the motorola, Temporarily kludged a used G-Luxon in there so I can get online), and behind the tx from the phone line on the Netopia. Any suggestions as to what to replace these with?
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: Best replacement for CrapXon KF?
    UPDATE: Ordered some Rubys from the BCN store for both modems. Only two I couldn't find were a 25uF/22V, and a 3300uF/16V (Seen plenty of 6.3v 3300s though)
    • retiredcaps
      • Apr 2010
      • 9271
      22uF 25V is here
      https://www.badcaps.net/store/produc...roducts_id=102
      What does DC voltage does the power adapter provide? If it is around 5V, you can safely use 3300uF 10V.
      --- begin sig file ---
      --- end sig file ---
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        It uses 12VDC. For the 470/16 near the DC jack I ordered a 470/25 for a little more headroom.
        I see that, but what goes there is a 22/35. (I got my #s mixed up it looks like, I meant 22uF/35V)
        • retiredcaps
          • Apr 2010
          • 9271
          If your DC adapter is outputting 12V DC, then a 22uF 25V will work fine even if the original is a 22uF 35V. Even a 22uF 16V will work fine if the 12V DC adapter is regulated. If the DC adapter is unregulated, it may run higher than 12V without a load.
