Caps? What is The Volts Value
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    I Know The Value Of These Capacitor SMD is 220uf ( 220 Micro Farad)...
    I have Question? What is a Volts Of This Capacitor
    [/IMG]
    Can you Teach Me?
    Tia
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Caps? What is The Volts Value
    what is it off - can we have a picture of it on the board
    Is is smd / surface mount / through hole
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      Thank You For Reply in my T.S Sir Selldoor
      Its a SMD (Tantalum Capacitor), I Know the Farad 220uf
      I Curious about the this "965P8" with "g" Attach letter and Numbers
      Can you Explain That or Those are the Volts Code... hehehe
      I'm apologize Becouse I'm Newbie... Thank's
      O.T Anyway it is a Found in HP Compaq CQ40 (AMD PRocessor)
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Ok - what is the board designation number C**
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          C59... The Loction of This Capacitor Backside of CPU...
          I Guess. I Think It is 4v or 6.3v ... But How Come any Explanation what is The Voltage Value of This Capacitor on Data Sheet...
            G = 4V.
            Please don't send me messages asking for help.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Good guess! Problem is there is no standard agreed marking for smd caps let alone tantalum ones. Also the placing of the G is a problem in that it could indicate the tolerance of the Cap 1% 2% 5% etc or the voltage.
              I did find this
              http://my.execpc.com/~endlr/markings.html
              Which has a table which says that G might =4 volts
              So I have no idea what the marking on the cap means Date code Factory code or what
              BUT according to the Schematic C59 is a 220U 4V cap
              EDIT Good Guess was aimed at Lorins not Tom didnt see his post too busy messing with the pic
              • lorins_core
                BlackSmith
                • Dec 2012
                • 551
                • Philippines
                Thank You Guys To Help Me... Specially to Sir Selldoor. Buddy More Thank You To Your Time and Effort to Finding a Solution to my Question. I Give +10 to Your Kindness
                God Bless You all...
                I wondered What Volts Of Capacitor This, In Manufacturer Marking Only. Now i know :-) :-) :-)
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
