Evercons = GSC = Bad Caps (tm)
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    Hi guys. As I already suggested earlier in this thread:
    https://www.badcaps.net/forum/showthread.php?t=1802
    I suggest adding Evercons as BAD CAPS.
    Now I just got another EXACTLY same JetWay N2PAP Ultra board and quess what - it stoped posting today - and I think you guys can quess why based on these pictures:
    Now some very interesting observations. These are the only two ones that are bulging from the whole board. And the second thing is even more interesting - the VERY same design, color and everything - just size 2200uF 16V caps on the VERY same board caps are labeled GSC!
    I think it is safe to assume that Evercon and GSC are produced by one company and they are comparable in terms of ... well, how to say it politely...
    You know
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • yanz
    • Nov 2004
    • 910
    Re: Evercons = GSC = Bad Caps (tm)
    evercon is still used in some recent motherboards and graphic cards iirc. just avoid focxonn/winfast brand... (sorry if i'm bashing a brand).
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      both gsc and evercon seem to be something to do with http://www.gensales.com.tw
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
