Should I replace bad caps or wait untill failure?
  • Churny
    • Nov 2012
    • Uk
    Is it worth the hastle of replacing them or should I wait till it fails ?
    The pc is running fine
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Should I replace bad caps or wait untill failure?
    Well what are you asking about? Power supply, motherboard, video card??? What brands? I usually recap the power supply and wait for the rest to fail before replacing.
    • severach
      • Aug 2007
      • 1055
      Depends on the cost of failure. For a server replace them at scheduled downtime. For your home computer the cost may be negative because the failure may prompt you to buy new equipment you wanted anyways.
      sig files are for morons
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Read the stickies.....or if you're too lazy:
        https://www.badcaps.net/forum/showthread.php?t=211
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          This is like asking should you get cancer treated. You're doing fine for now...
          Yes, definitely replace the caps!
          • Thomasraud
            Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
            by Thomasraud
            i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
            QUOTED
            -It works on charger (without battery connected-only charger)
            -It works on battery (without charger connected-only battery)
            -& it also works when plugged in battery & charger, but it's not charging the battery
            //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
            and..
            QUOTE
            The IC cannot maintain the input current level
            06-28-2022, 06:47 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • ctroxtell
            Carrier HK50AA063 display controller common failure help
            by ctroxtell
            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
            02-05-2025, 05:31 PM
          • Sojke
            IT8585E Programming
            by Sojke
            How to program IT8585E on RT809F (H) programmer?
            It wont work on ITE_ADAPTER_V1.5 board (IT8580, IT8586, IT8587 work when soldered on board)
            Please help.
            I tried with cable for keyboard it does not work either (Laptop is G750JZ)
            005: The currently selected:IT8585_ISP @PEB-1, capacity: 1Mbits, 128Kbytes.
            006: http://www.ifix.net.cn/thread-47221-1-1.html
            007: >------------------------------------OK---------------------------------------<
            008: Wait for the chips enter into the ISP status, please wait...
            009: Wait...
            10-28-2021, 01:35 PM
