are they same?
  • bohaboha
    • Nov 2012
    • 1044
    • sweden
    are they same?
    Hello all of you out there i have 2 capasitors 1)PET A5E 16v 470uf 105deg(MK)
    the 2)212C(M) G.LUXon 12v 470uf 85deg i wonder if can replace the small one on the picture instead of the bigger one ho is swollen thank you
    very sorry i can not insert image here the first one is 8mm and the other is 1cm
    thank you
  • mo000
    470uf tantalum caps replacement
    by mo000
    hi
    motherboard toshiba C50 PT10F
    i found 2 bad 470uf tantalum in cpu sircuit making short .
    but i only have 380uf tantalum can i replace them with electrolytic caps .
    05-11-2021, 10:44 AM
  • Perry Babin
    Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
    by Perry Babin
    I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
    This is for the primary side of a switching power supply in a car audio amplifier.
    Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
    10-16-2025, 05:20 AM
  • howardc64
    UN55NU7100F failed edge lit LED bar, poor quality replacement LED bar AND bulging cap on PSU
    by howardc64
    Just typical LED bar failure repair but discovered a couple of things worthy of posting
    PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
    2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band Can't detect when testing the LED bar along...
    10-13-2025, 05:56 PM
  • kotel studios
    Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
    by kotel studios
    Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
    State I got it in:
    Squealing from the PSU
    After logo I get a blank screen
    After 10 seconds of having a blank display w/ backlight the TV dies
    Give it 7-10ish seconds again and it starts to bootloop.
    What I did so far:
    Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
    Checked all voltage rails:
    5VSB - 4.8V
    AMP+13V - 14.4V
    13V - 12.98V (in manual 12V)...
    09-21-2025, 02:00 AM
  • chth96
    How Can I test PWM DM0365R?
    by chth96
    Hello
    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
    06-18-2025, 04:14 PM
