Asia'x crap - any info (datasheet)?
  • Behemot
    • 4845
    • CZ
    Been seeing them a lot lately in EuroCase PSUs. Did not find any info besides it is supposedly made by Fuhjyyu. Not datasheets exists even about them so I guess I won't ever find anything about Asia'x. But if you guys got some info, feel free to share
    These PSU's are usually crappy, that means having wide mantinels, but aso for the small caps I would rather use correct replacements. I am betting on general purpose, thus swapping the small TNX for Nichicon VZ.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Asia'x crap - any info (datasheet)?
    No idea where you can find any data sheets on them, but when I see an output filter capacitor of unknown brand in a SMPS, I just pick whichever is cheapest from my list of "approved" PSU caps...
    Usually Chemicon KY/KZE/LXY/LXZ, Nichicon PW/PM/PS/HE/HD, or Panasonic HFQ (discontinued, I think)/FC/FK/FR/FM. Normally I go with the entry-level low ESR series from the above list, if space permits.
    • Behemot
      • 4845
      • CZ
      That's the problem - e.g. KY and others are low-esr, yet more and more you see general purpose on driving/feedback circuits, and these tend to be accepting GP caps only recently. There use to be craps having current e.g. arround only 10-20 mA, yet low-esr caps can do 100-200 mA. That means the same difference in ESR. That's why I am asking - I have both now, just don't know which to use
      But as I said, fortunatelly these crappy PSU's have wider mantinels so I think both may do fine. And GP are cheaper
      • AJ847.63e
        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
        by AJ847.63e
        Hi Folks,
        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
        05-06-2025, 10:37 PM
      • SoulFreeze
        Help finding datasheet for component marked G34662
        by SoulFreeze
        Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
        Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
        Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
        05-01-2025, 03:56 AM
      • Rainbow_Chameleon
        Searching Datasheet for AM113 IC by O2MICRO
        by Rainbow_Chameleon
        I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
        Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
        If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
        On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
        So if anyone has a datasheet or at least...
        01-23-2025, 12:03 PM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • piernov
        Core 2 "gaming" build with SLI
        by piernov
        My turn to post a build I guess, wasted way too much time on this one…
        First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
        Everything done with random parts I had lying around.
        Specs :
        • CPU: Core 2 Quad Q9450
        • RAM: 2x2GB KHX6400D2K2
        • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
        • MB: P5N-E SLI
        • PSU: Antec Basiq Power 550 Plus
        • HDD: Hitachi Ultrastar A7K2000 1TB
        • ODDs: DVD ROM, DVD RW
        • Case: not sure
        Cooling:
        • 92mm rear fan
        • 120mm front fan
        • Additional heatsink on southbridge
        05-20-2023, 11:38 AM
