question about installing a cap rated for a lower temp
  • kq702
    • Jul 2012
    • 15
    • usa
    Hi I have a motherboard which is untested however I can see it has one visibly bad cap. It is 6.3 V, 3300 uF, and the temp is rated at 105 C.
    I have a spare cap laying arround that is the exact same physical size, and has mostly the same specs. The only difference is the spare one is only rated at a temp of 85 C, not 105.
    I understand that installing this one is not a good long term solution, however if I install it will it work for even a small amount of time? I just want to test the motherboard. If I install it and the motherboard works I will remove it and order the cap that is rated for a higher temp. So can I use this one for now as a test? Or would I risk further damage by installing it?
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: question about installing a cap rated for a lower temp
    yes it should work! in the area that the one cap was blown, the others of same value could be bad as well. would suggest a reacap of all of them if ya keepen board for the long run!
    • yyonline
      • Jul 2009
      • 692
      On a motherboard, 6.3V 3300uF capacitors are almost definitely a very low ESR capacitor. 85 degree rated capacitors are almost definitely not low ESR. I wouldn't expect it to work for very long, if at all with that replacement.
      • Perry Babin
        Operating caps well below rated voltage
        by Perry Babin
        I think this has been answered but I couldn't find the thread.
        Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
        So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
        If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
        Or would it require reforming?
        05-23-2024, 05:43 PM
      • tmcw
        Drying Oven - Preset Temp Fail
        by tmcw
        Here's an unusual one...
        This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
        It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
        However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
        01-21-2021, 03:11 AM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • foshland
        MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
        by foshland
        Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
        Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
        External temperature (motherboard temp) is working OK, 27ºC more or less
        In windows, all the software I have tested shows correct the Core temps
        12-16-2023, 09:08 PM
      • Phil289
        Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
        by Phil289
        Hi
        Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
        Is there any reasons why they shouldn't be used?
        I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
        If I can't find any Panasonic what would be any other good makes to consider?
        Thanks 🙂
        09-25-2022, 03:02 PM
