Delcon caps
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Delcon caps
    Anyone know about these? Have a small Archer 4 channel amp (2 front, 2 rear) that are full of these, so far only had one bad one on the front left output (causing low volume on that speaker). Using this amp to drive some undereave mounted speakers
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Delcon caps
    Speaker coupling cap from the amp output to the speaker terminal?
    If so, keep in mind that you'll need a cap whose ripple current rating is the same as the speaker current. Use Ohm's law, speaker impedance, and output power to arrive at this.
    Are those caps gray in color, with "Japan" or "JAPAN" printed on their sleeve, by any chance?
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • Hemingray
      KABOOM!
      • Jul 2010
      • 143
      Re: Delcon caps
      No, black with "Delcon" and the value printed on them.
        by momaka
        03-12-2025, 03:42 PM
      • Delicieuxz
        Replacing caps in an old speaker system. Should I use a higher value here?
        by Delicieuxz
        I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
        https://youtu.be/1LRIzePlma0?t=273
        I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
        Would 680uF be good value to try in place of the 470uF originals?
        06-25-2023, 08:27 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
