Anyone know about these? Have a small Archer 4 channel amp (2 front, 2 rear) that are full of these, so far only had one bad one on the front left output (causing low volume on that speaker). Using this amp to drive some undereave mounted speakers
Delcon caps
Re: Delcon caps
Speaker coupling cap from the amp output to the speaker terminal?
If so, keep in mind that you'll need a cap whose ripple current rating is the same as the speaker current. Use Ohm's law, speaker impedance, and output power to arrive at this.
Are those caps gray in color, with "Japan" or "JAPAN" printed on their sleeve, by any chance?"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by DelicieuxzI'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
https://youtu.be/1LRIzePlma0?t=273
I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
Would 680uF be good value to try in place of the 470uF originals?-
by eryjusHello,
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
