Ltec Caps
  • Whatwhat
    • Jul 2020
    Re: Ltec Caps
    I truly don't belong on this forum because I don't have the knowledge of the typical member, but I had to register so I could post to this.
    So my PSU failed and I replaced it. It was a 430W Antec Earthwatts. It's powered two computers and has pretty much been on continuously for twelve years (bought in 2008). I tore it apart to see what was inside and I found a large Aishi, a couple of Rubycons, CapXon, nichicon, Taicon and Ltec. Googling Ltec is what got me here. I don't know what failed. None of the caps were bulging or leaking. Anyway, I'm impressed with the life I got out of that thing. Cheap or not, those components held up.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Re: Ltec Caps
      Welcome to Badcaps
      If you want to give it a try to repair it then here are two good threads to get you started:
      https://www.badcaps.net/forum/showthread.php?t=65425
      https://www.badcaps.net/forum/showthread.php?t=37779
      Otherwise yea, that PSU has had a good run, sometimes even low tier caps can last a long time!
      Other times it takes just a year, it's all down to luck really
      • Murray Bozinsky
        • Dec 2020
        Re: Ltec Caps
        In a AcBel 12V 3,33A PSU it blow away the electrolytic capacitors in output - 2 pcs 1000uF 16V Ltec. I replaced it with 2x low ESR Panasonic 1000uF 25V and it works well again
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
