XP harder on caps than ME?
  • fed32169
    • Aug 2006
    I got an old k7t pro2 (6330 v1)w/an Athlon 1Ghz that has a plethora of Chhsi junk (every one of which will be removed and destroyed in some satisfiying way) upon it,2 of which i already replaced(by the AGP)as they were about to spew, but the 4 caps around the processor are nichicons("HD"; plain aluminum style)and I figure if the ain't broke, you know, but as for the 3 near the north edge they're 3900's@10v "YAGEO"dark green /gold lettering.
    This machine is in a new case w/400 W supply, which has handled 2 other boards admirably in the past 45 days.
    Lemme tell ya this thing has been a severe pain in the pick a fleshy area.
    had 2 turn off EVERYTHING in the bios to get it to setup win xp, which it finally did after 29 hours and four restarts after errors.The inability to operate with the internal cache enabled really does a bad thing to usefulness and also to my mindset.
    I just wanna set this old thing up as a file server in the closet w/ a couple 250's worth of tunes in the box.
    The thing is it sets up WIN ME in a blink, and will run it for days without having to touch the bios at all!
    I wonder why XP is so hard on these caps, whereas ME ain't.Is this the case , or what am i missing?
  • linuxguru
    • Apr 2005
    • 1564
    Re: XP harder on caps than ME?
    I suspect that ME might be harder than XP on the caps since it doesn't use CPUIDLE to idle the CPU in low-load states - YMMV. LInux is the best for CPU power management.
    Regarding the caps, the Nichicon HD bare-aluminium lacquer-finish caps are excellent, and Yageo (holding company for Teapo, Luxon, etc.) should be OK, but you can try replacing them if you want. Chhsi is definitely crap.
    • arneson
      • Sep 2005
      • 1267
      I have a machine that will run ME no problem but blue screens and will not load XP.
      After also going thru hell with this I just had to accept it, the on board memory was glitched. My conclusion may be different from yours but XP uses memory differently regaurdless of caps.
      Jim
      • Rainbow
        • Aug 2005
        • 1375
        If there are any Chhsi left, replace them. They can fail without bulging.
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
