Replacements for Samxon GF
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Hello
    What is the best replacement for Samxon GF? They are used in Insung P-2000 power supply for Topfield TF600PVR.
    I will be ordering from http://thecapking.com/.
    I need replacements for:
    2x 1500uF 10V 10mm
    2x 680uF 25V 10mm
    1x 330uF 25V 8mm
    1x 220uF 35V 8mm
    Should I also replace the Samxon KM series capacitors? They are visibly OK.
    If yes, here's the values:
    1x 1000uF 10V 10mm
    3x 330uF 25V 8mm
    1x 220uF 35V 8mm
    Thank you in advance.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Replacements for Samxon GF
    While the owner of this site does know thecapking.com, you do know that asking badcaps members to pick and choose caps from a "competitor" is like going to Pepsi and asking what Coke products are good drinks.
    There is a store here
    https://www.badcaps.net/pages.php?vid=26
    --- begin sig file ---
    --- end sig file ---
    • severach
      • Aug 2007
      • 1055
      What did you say about Coke and Pepsi?
      http://www.youtube.com/watch?v=-imHBWKhtu0
      sig files are for morons
      • japlytic
        • Oct 2005
        • 2086
        You should replace all but the 400/450V unit with Chemi-Con KY Series.
        • Uranium-235
          Need replacements for Samxon HP
          by Uranium-235
          I've been looking through all the best brands (rubycon, nichicon, UCC) with little success (edit, I mean I find them out of stock, or only stocked in other countries). Is there a mid-range brand for these
          Must be:
          315v-400v
          470uf (560 maybe)
          1.7ARMS
          30mm diameter max
          40mm height max
          Mid-range caps are fine and you guys are up to date on other brands
          for: Plasma TV main power board
          I know some are bloated and I plan to replace as many as I can
          Middle mains are Samwa...
          03-05-2022, 11:05 PM
        • slybunda
          Gemcon capacitor replacements?
          by slybunda
          taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
          there are 2 caps which im looking to get replacements for.
          Branded as Gemcon
          single 100uf 16v 6.5mm x 11.5mm
          single 100uf 50v 8mm x 11.5mm
          lead spacing is around 3mm
          there is space for 16mm tall caps
          rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
          the caps have...
          02-05-2024, 03:36 PM
        • chth96
          Can I replace KME cap with Samxon GF cap?
          by chth96
          Hello.
          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
          04-17-2024, 07:11 AM
        • dhan
          HELP: 330uF tantalum capacitors
          by dhan
          Hello Everyone,
          I'm just a bit curious or let say uncertain for these caps.
          I have tried to replace NEC tokin 0E907 with 4 pcs of 330uF 2.5V.
          the laptop works fine.
          then another laptop (different laptop) came after a year, with the same issue.
          but this time I have a different type of 330uF tantalum caps.
          the one I've used before was 330 with small letter e on the markings.
          e = 2.5V, but this time I have 330uF with letter d on the markings
          d= 2.0V, right? correct me please.
          the question is, does 4 x...
          11-15-2020, 01:31 AM
        • прямо
          Help me decide which MOSFETs are suitable replacements
          by прямо
          Friends,
          I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
          MDD1502 (high side), 48.5A 7.8mOhm
          MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
          VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
          Here are the ones...
          02-01-2024, 09:06 PM
