Need help identifying caps
  • overclockedpc
    • Aug 2012
    Hey guys, I have a Vizio tv that has two pink vertical lines across it. My best guess is that some of the caps on the panel's PCB are starting to go.
    I'm attaching a pic because I can't ID these caps. Other than the fact that they're SMD alum caps, my best guess is that they MIGHT bee 33uF? But that's about all I can decipher and Vizio won't give out schematics.
    Please help!
  • overclockedpc
    • Aug 2012
    Re: Need help identifying caps
    nobody has any ideas, huh?
    • mootink
      • Jul 2012
      • 43
      what is the model number of the tv and the board
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        This question - well very similar has been asked before with no conclusive answer
        https://www.badcaps.net/forum/showthread.php?t=17792
        As you have a working machine suggest you measure the voltage across the caps when it is working. assume the 33 is 33uf as the only number which fits any pattern and try some caps that would cover the voltage measured.
        Digikey are pretty good at identifying components you could try them or check cap catalogues
        of any cap manufacturer you can think of.
        Take one off and see if there are any clues underneath
