no picture no sound vizio L42hdtv10A
  • larry rush
    • Jun 2012
    • us
    no picture no sound vizio L42hdtv10A can anyone help
  • killian6pk
    • Apr 2010
    • 502
    Re: no picture no sound vizio L42hdtv10A
    Post this in the the Troubleshooting TVs and Video Sources of the Electronic Theory & Troubleshooting Forum and you will get some help.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
    • ggil44
      Vizio M65-E0 No Picture, No Sound
      by ggil44
      Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
      09-03-2024, 08:30 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
