Hi I am trying to part rebuild my powerboard from my Tevion 47inch LCD Tv, however I am not sure about the physical size of the Capxon capacitors that I am replacing. Some are coded C708 or 706 is this a code for the physical size of the capacitor? I can not find any info on these codes.
Many thanks in advance for any help
Primo.UK
Primo.UK
. But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
