So I got an old Compaq system for free, manufactured sometime in late 2002. I opened it and discovered that it has obviously never been cleaned before, it was absolutely filthy. I couldn't even see what color most of the caps were. After cleaning it, I discovered that 3 of the (I think 8) caps right next to the CPU socket were bulging. All of them are nichicon. I tested it and the computer booted into the BIOS. It's got a Socket 478 Pentium 4 2GHz/512K/400 CPU, 2 DDR RAM sticks, a single IDE HDD and 2 optical drives. Think I got unlucky or do you think the heat build up from the dust killed them? Or was that the period when nichicon had a funk and released questionable caps?
I'm also surprised that the 12V on the PSU didn't die, it's only rated at 5A!!! But when I was cleaning it I could see that all the caps in it were Rubycon and it seems to be well built for such an old PSU.
So sitting around, I have a Socket 478 Asus board that I'm pretty sure has a dead AGP slot, and all of the caps next to the CPU on it are Rubycon's. If they are compatible (I can list info when I get home) would it be worth it? Or is it not worth it because of capacitor aging? The Asus is from 2004 and has about 40,000 hours of use on it...Is this a bad idea to replace just some instead of replacing all of them? I was just going to throw a graphics card in there and use it as a side computer for watching videos/internet
Thanks for reading! And I can also upload some pictures when I get home
