Old motherboard with dead nichicon's :(
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So I got an old Compaq system for free, manufactured sometime in late 2002. I opened it and discovered that it has obviously never been cleaned before, it was absolutely filthy. I couldn't even see what color most of the caps were. After cleaning it, I discovered that 3 of the (I think 8) caps right next to the CPU socket were bulging. All of them are nichicon. I tested it and the computer booted into the BIOS. It's got a Socket 478 Pentium 4 2GHz/512K/400 CPU, 2 DDR RAM sticks, a single IDE HDD and 2 optical drives. Think I got unlucky or do you think the heat build up from the dust killed them? Or was that the period when nichicon had a funk and released questionable caps?
    I'm also surprised that the 12V on the PSU didn't die, it's only rated at 5A!!! But when I was cleaning it I could see that all the caps in it were Rubycon and it seems to be well built for such an old PSU.
    So sitting around, I have a Socket 478 Asus board that I'm pretty sure has a dead AGP slot, and all of the caps next to the CPU on it are Rubycon's. If they are compatible (I can list info when I get home) would it be worth it? Or is it not worth it because of capacitor aging? The Asus is from 2004 and has about 40,000 hours of use on it...Is this a bad idea to replace just some instead of replacing all of them? I was just going to throw a graphics card in there and use it as a side computer for watching videos/internet
    Thanks for reading! And I can also upload some pictures when I get home
  • mariushm
    • May 2011
    • 3799
    Re: Old motherboard with dead nichicon's
    The old systems used the 5V rail to feed the processor and possibly also the memory modules.
    AGP runs on 3.3v and 1.5v but these are probably also generated from the 5v rail.
    So the 12v @ 5A is mainly used by hard drive motors, fans and maybe serial ports and other minor stuff, therefore at that time it was plenty.
    Nichicon had the HM series bad from 2002 to 2004 I believe, but I'm not sure right now... maybe also HN was bad around that time, search the forums. It's possible they died due to heat and dust.
    As for capacitors compatibility, list the series and values here and you'll get some feedback.
    Sure, post pictures. I like to see old hardware.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I know old systems like S370 used the 5V but I'm pretty positive S478 uses the 12V, as well as the GPU (AGP). And I thought all HDD's/CD Drives use 5V, and 3.3V is used by fans and RAM?
      And yeah when I get home I will for sure list the info of the caps from both boards and upload some pics
      • mariushm
        • May 2011
        • 3799
        There are boards using 5v primarily, especially when it comes to custom oem boards.
        See for example:
        http://www.asrock.com/mb/overview.asp?Model=P4VX4
        http://www.asrock.com/mb/overview.asp?Model=PE%20PRO
        http://www.asrock.com/mb/overview.asp?Model=P4i45G
        You can find boards from ECS or MSI that are without the 12pin connector also easily.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Alright so as of now my camera is dead and can't find the charger but I'll upload pics when I can. There were 6 caps in a line and I desoldered 5 of the 6 (one was close to some motherboard paths and left it, I'd be nervous to get solder on it) out of the 5, only about 2 look dead but I figured might as well replace most of them. They are nichichon 2200uf 6.3V 105C HM(M) H0214
          The rest look okay, most of the important ones are nichichon, and the less important caps are Teapo (only like 7) but there are also 2 decent sized caps (1000uf) that I've never heard of before, Yageo? How are those? They look like Teapos so they're probably from the same company...
          • UserXP
            • Apr 2012
            • 444
            • Serbia
            It is really interesting how there are so many different names for all kind and brand of capacitors which mainly ends with "o" or "con"...
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Intel uses the 4-pin 12 V spec, way before AMD did.
              Even in 2002, I would expect 99 percent of boards to have a 4-pin 12 V plug.
              Asus' latest board to use 5V was the A7N8X family.
              IIRC, it's an Intel violation to use 5V for Pentium 4 and later.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Yeah, I figured so. It has a 4 pin 12V connector. And yeah there are so many different brands with similar names!
                Anyone know if this was a bad series from nichicon? and what can I replace them with?
                • dmill89
                  • Dec 2011
                  • 2534
                  I'd probably go with direct replacements. Nichicon has long since fixed the problem with the HM/HN series and current production caps in those series are very reliable. Since the Nichicon HM caps on your board were produced during a bad run I would recommend replacing all HM/HN caps on that board including the ones that haven't bulged, or you will likely have to repair it again in the future. The Teapos could also be an issue but if they are in non-critical areas and are good you should be ok as long as the board is not used in an application where it is run 24/7 or high reliability is required (i.e. server application), If reliability is a major concern I'd probably replace those as well. I'm not too familiar with Yageo caps, maybe someone else here has some experience with them.
                  • tk3000
                    Dead Laptop Motherboard, then refurbished one installed...
                    by tk3000
                    My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
                    Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few...
                    08-20-2022, 08:45 AM
                  • araxnido
                    Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                    by araxnido
                    Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                    When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                    06-10-2025, 09:26 PM
                  • DrvLikHell
                    Dell Latitude E6540 - 2nd dead motherboard
                    by DrvLikHell
                    Greetings and sanitations! Several years ago I received some really awesome help on this forum for fixing my monitor (which is still working) so I figure maybe someone can help with this laptop issue.
                    I have a Dell E6540, motherboard 9411P, DP/N:VWNW8. A year ago it died a strange death where at first it wouldn't turn on all the time, but would turn on when it felt like it, then it got worse where it wouldn't turn on at all and I would just get a flashing light. So I replaced the motherboard with a matching part number board. (I still have the old motherboard) Now a year later this...
                    01-30-2021, 02:36 PM
                  • Archimedes
                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                    by Archimedes
                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                    Fans are spinning. Blindly could install windows11 and got the device manager...
                    07-30-2024, 05:14 PM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
