What do you think about these capacitors?
  • jonnytx
    • Apr 2012
    • 11
    • Russia
    If this is not fake, what a better buy? Plan to use them in pulse circuits.
    Rubycon YXA:
    http://www.ebay.com/itm/ws/eBayISAPI...m=260801127444
    Rubycon MHE:
    http://www.ebay.com/itm/ws/eBayISAPI...m=170534491627
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: What do you think about these capacitors?
    rubycon shipping from china = fake.
    https://www.badcaps.net/store/produc...roducts_id=150
    If you dont buy from me, buy from digikey or mouser.....you atleast won't get fake chinese knockoff garbage.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • jonnytx
      • Apr 2012
      • 11
      • Russia
      If I buy capacitors from you, delivery to Russia will cost $ 8.00?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Yes. I've shipped to Russia many times....I've never had anyone report back that the package never arrived. Russian mail seems to be reliable.
        Team : 49813
        Join in!!
        Team Stats
        • jonnytx
          • Apr 2012
          • 11
          • Russia
          Why is the diameter of your capacitor is different from that given in the manufacturer's documentation?
          • mariushm
            • May 2011
            • 3799
            Because he has ZLJ , you're listing the specs for ZLG.
            ZLJ:
            • jonnytx
              • Apr 2012
              • 11
              • Russia
              Oh, sorry, I'm confused. Moderators can delete the past post. I'll try to make the order.
              • dragon3x
                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                by dragon3x
                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                power on.
                Here are some examples :
                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                switching supply area).
                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                than 6.3 V.)
                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                I replaced capacitors with aluminum-polymer.
                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • Ady2017
                Are there any datasheets available for Elna RJG capacitors?
                by Ady2017
                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                05-25-2025, 02:19 PM
              • ctroxtell
                Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                by ctroxtell
                I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                01-03-2025, 08:57 PM
