Why are crap caps still in use???
  • Chumly
    • Apr 2012
    • 5
    Re: Why are crap caps still in use???
    Let the customer suck up the cost then. Had this in my own thread, but it wasn't fit for my own topic. I fixed 16 Samsung 204B's a while back and am tackling 24 225BW's and two more 204B's sitting in our graveyard:
    Going with the BadCaps question of "why is this still happening?", it's hard to really figure out why this happens. Like iPhones, I guess the upgrade cycle shortens and most aren't expected to keep LCD's very long so it's "Good enough" and get's them through the warranty period.
    Opened up an Asus 23.6" just for giggles and found all good cap readings and great brands. So, $3 per monitor to make a quality product is all it takes? These are out of date LCD's, but most owners out there would be glad to pay more to keep them running longer instead of land-filling them. They're just computer monitors at this point though (The 225BW was my 1st LCD and replaced a Sony 22" CRT. That Sony CRT was $2,800 and still the best picture I've seen even today...so people WILL pay for quality)
    Guess what's in the Panasonic 46" plasma? Awesome Pany caps. Sharp got the rights to the Pioneer Kuro panel tech, but they're using crap IC's behind that panel and just isn't the same product. They want $5,300 for a 50" and I just can't trust them to last. It just seems like a secret that there's more to a TV than the panel.
    I digress. People seem to upgrade very expensive stuff these days more frequently than they use to in order to keep up with the Jones' so the product doesn't have to last. In the lower cost stuff, it's a battle of the budget. $150-180 seems to be the bloated range of displays. No one keeps a display or TV for more than 10 years. But why save $3 when making them?
    _____________
    I was an engineer at Intel (and AMD, and 3DFX, and...). We didn't skimp on parts like caps as our validation didn't allow variance, let alone failure. It didn't cost more in the long run because these parts just didn't die from crap 3rd party parts and cutting corners. Like OCZ, XFX/Pine, or Mushkin; they can feel good about putting lifetime warranty on their stuff due to not cutting corners. Other brands are "OK" because they clear 3 year warranties.
      There's a lot of hype about these new Finlux TVs in the UK.
      Absolute rubbish - no better than any supermarket brand. Made by Vestel.
      Same for another brand - "Kogan".
      But, people will buy them, because it is a name. The average customer is sadly quite stupid, but also limited, when it comes to evaluating product quality. After all, you can't bring your screwdriver to the shop and disassemble the TV.
      Maybe there should be some way to guarantee quality? Problem is, how to define it - I mean even cheap caps can last in certain situations, and things like the Vizio LDO failures can't be easily characterised. I think offering a warranty is a good demonstration of manufacturer confidence though, as the manufacturer's ass is on the line if products go sour. Panasonic for example sell their TVs with a 5 year warranty. I bet less than 1% come back on that, because they are very well built.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        On Vestel sets, a part of the issue is that they push the designs too hard. Their lifetime can be greatly increased by simply reducing the brightness... On Vestel CRT sets, the contrast is set so high from the factory that the tube actually goes out of focus on bright areas.
        I own three CRT TVs built on Vestel chassis, and on all three the contrast is set lower than 1/4 in the menu. The oldest one is 6 years old, and none of them have had any issues yet. I've fixed a couple of them for clients, and i follow a local service forum, there's a few common issues on Vestel CRT chassis, most frequently the HOT burns out due to a capacitor failure. That cap's lifetime is directly affected by the transistor's temperature since it's right next to the heatsink - so simply running the set at lower contrast makes that cap last a lot longer, and the picture actually looks better like that.
        A working TV? How boring!
        • Chumly
          • Apr 2012
          • 5
          No you can't bring a screwdriver to split them open, but you can be a voice for others. Look out for the weaker of the herd or we'll just get lesser products as a whole. The wolves do not dictate product satisfaction.
          But this is a small section of the interwebs that knows more than the average bear. I don't know the brands you mentioned. Maybe because they're set to fail on a world market.
            by momaka
            03-12-2025, 03:42 PM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
          • madscientist750
            Replacing electrolytic caps by solid caps on old motherboards
            by madscientist750
            I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
            I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
            I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
            10-19-2025, 06:10 AM
