Bad caps irony...
  • Tom41
    • Oct 2005
    • 338
    • England
    Bad caps irony...
    Has anyone here had experience with 'ironic' bad caps? That is, either a motherboard with venting caps works perfectly, or a board with caps that look 'good' fails to POST etc.
    I'll start with a PC at work... nearly ALL the (GSC) caps have vented, and yet the PC still runs without any problems!
    At the other end of the scale was the PSU on my PC at home. One very slightly bulged Fuhjyuu, and the PC wouldn't get past the POST
    Anyone have similar stories of cap irony?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • yanz
    • Nov 2004
    • 910
    Re: Bad caps irony...
    one of my epox 8k3a was full of bulged & leaking GSC arround atx connector and bottom area of the vrm input and it was doing fine until i recap it. that's why i join the forum in 2004 (when only one GSC caps bulging visible) but only start to post in mid 2005
    altough from all epox board i ever get in my hand with GSC craps, it would need to take at least six bulged GSC to make the board south (unstable).
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Back in the dark ages (1999 or so) I had a BP6 packed with Junkcon caps that ran over 6 months with visibly failing caps. It did finally become unstable and fail, so the inevitable always prevails with bad caps....
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        wait till you find a bad cap in a cap checker!a friend brought me a dick smith esr meter that died shortly after assembly.
        a cap had shorted.dead givaway as it got hot enough to melt the wrapper and the batteries got hot.
          by momaka
          03-15-2023, 10:17 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
