Please help power supply problem
  • Neotheone
    • Mar 2012
    • 38
    • England
    Hi, posted before and help was given but still having problems - I have a 42" alba tv that went pop so checked for bad caps but identified none that where obvious, anyway f800 t 3.15a 250v fuse blown replaced and blew again - I also have another board bought from ebay but was slightly different (little difference in cap type and extra power connector. taking reading from the bridge rectifier and as you would think the apparent good board only measures correct on way only but the other shows measurement in both directions (in circut) taken them both out and they measure fine - one way only > why in circut does the faulty board bridge rectifier show both ways ??? open/short nearby and if so what ??
    17pw26 3 power board known pain in the backside i have heard... any help would be helpful - thanks
  • Neotheone
    • Mar 2012
    • 38
    • England
    Re: Please help power supply problem
    Hi, these are the two boards one with note on is apparently good boar but are they comparable?
    • Neotheone
      • Mar 2012
      • 38
      • England
      see pic - items burn and also no power from when son inserted scart lead when switched on .. thanks again
        supply problem
        You have a Vestel power supply, and probably a Vestel TV with the Alba name on it. Sadly, Vestels are the Lada of the TV world, absolutely rubbish.
        The most common cause of this problem with Vestel TVs is the PFC MOSFET and/or diode going short circuit. These often fail due to the big black capacitor going too low in capacitance causing problems with the other components.
        The board you have is most likely compatible. As long as the connectors match it shouldn't matter. Manufacturers like Vestel like to play Russian Roulette with their power supplies, shooting off components from a distance until they stop working and then replacing the last component. So it's not uncommon to see boards with tons of missing components.
        • Neotheone
          • Mar 2012
          • 38
          • England
          thanks for the advice - if possible would you know why the bridge rectifier would give a faulty reading in the board that has failed but ok in the other board when switched? thanks again
          • Toasty
            • Jul 2007
            • 4171
            Because the bridge is not bad. What follows it in the circuit is.
            Likely the main switchers.
            veritas odium parit
            • Neotheone
              • Mar 2012
              • 38
              • England
              Right - I now have power through the tv main standby light on but when switching on it just flashes ? any advice
              • Neotheone
                • Mar 2012
                • 38
                • England
                Update replaced the ic chip and three transistors / mosfets q813 q814 q803 and also cap c380 now I think i have a s/c diode will report back on Sunday having a drink now so I will leave the electrics until tomorrow ..
                • Neotheone
                  • Mar 2012
                  • 38
                  • England
                  if you look at the mainboard you see a few wires attached and there seems to be a piece metal (half circle) should this be whole (full circle) and what is it for
                  • Toasty
                    • Jul 2007
                    • 4171
                    It's a ferrite core that is used for interference suppression/filtering. It is broken as it should be a solid ring. It is not the cause of any of these troubles.
                    veritas odium parit
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
