Newbie needs advice on cappies
  • albundyhere
    • May 2006
    I have an asrock P4S61 board that has a bubbletop cappy. Here are the specs:
    taicon
    0416 (M)
    105 celcius
    6.3v 1000uF
    farnell carries several types of the above specs. any advice on which one to get?
    thanx.
  • yanz
    • Nov 2004
    • 910
    Re: Newbie needs advice on cappies
    You'll need the low ESR ones. The 1000uF or 1200uF 6.3v (or 10v) would do if they are of good brand low ESR Japanese capacitor.
    You'll also need to inspect further, is the cap near the cpu socket? Are there any similar caps on the mobo? What is the diameter? You should replace them too if the problem sill exist after recapping. IMO your chance of success is great if the mobo still able to POST before the recapping..
    This is the caps i recommend:
    1000uF & 1200uF 8mm 10v Caps
    1000uF & 1200uF 10mm 10v Caps
    days are so short when you actually do something..
    • Cappy Oligan
      Newbie about to dive in with the leads. Safety advice please.
      by Cappy Oligan
      I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
      08-30-2024, 05:40 PM
    • Jidis
      Need T-Con Advice (Vizio P602ui-B3)
      by Jidis
      I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
      He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
      09-22-2025, 05:10 PM
    • zlr8r
      Advice on newer EC chip programming eg. MEC5107-LJ BGA
      by zlr8r
      Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
      i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
      09-16-2025, 09:54 AM
    • Borse2008
      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
      by Borse2008
      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
      • There’s
      07-15-2025, 04:55 AM
    • Green Probe
      Mosfet Advice
      by Green Probe
      Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
      05-22-2025, 10:49 AM
