hi chaps,trawling through here and trying to find a datasheet for the g luxon gr series ,cant seem to find one,has g luxon merged with teapo?,the results i get from google suggest so!,anyone have a link?,panasonic fm dont seem to do a 700uf 6.3v
g luxon datasheet
g luxon datasheet
fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Tags: None -
Re: g luxon datasheet
these will work
http://search.digikey.com/us/en/prod...376-ND/2433510
http://search.digikey.com/us/en/prod...2365-ND/613726
http://search.digikey.com/us/en/prod...0222-ND/266232
http://search.digikey.com/us/en/prod...1484-ND/756000
http://search.digikey.com/us/en/prod...1503-ND/756019
http://search.digikey.com/us/en/prod...1465-ND/589206
http://search.digikey.com/us/en/prod...1876-ND/756392
http://search.digikey.com/us/en/prod...1494-ND/589235Last edited by mariushm; 01-23-2012, 03:55 PM. -
thankyou mariushm,thats what i was looking for,even on the g luxon datasheet ,they didnt even list the 700uf !! well strange,hey hofixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Comment
Comes up as "Connection Reset" try again....
Here-Attached Filesif you find these attachements useful please consider making a small donation to the site
veritas odium paritComment
It's probably fake or a custom batch.
Most caps are +/- 20% and I'm sure what you replace wasn't really 700uF before it died, I think it's safe to go with 680uF.
You'll find a few 700uF capacitors on digikey but considering the GR series is a "general purpose" one with average specifications, I say don't bother.
Also, Panasonic caps actually are almost always a bit over the value they list so really, don't think it would be an issue.Comment
by pokerI can't find the datasheet for this chip's schematic. Can someone with information please answer?...
by ColdblackiceI'm trying to extract firmware from a GoXLR-Mini
https://www.tc-helicon.com/product.html?modelCode=P0DI7
I know it's not ideal, but I'm trying to extract the 64MB firmware without removing the chip. I've done this before, but I realize it's a case-by-case thing. Unfortunately, it seems this board's layout results in it getting powered by my SPI tool (Buspirate), failing extraction.
I believe the issue is the flash chip's HOLD pin unable to get pulled high, as the current for that pin dissipates elsewhere in the circuit. When I try to pull the HOLD pin...-
by LA1I am trying to find two smd datasheets for an Apevia 1000w prestige power supply ATX-PR1000W the SMD's are ST9S313 which is a SMPS supervisory chip and a EST 915HP or XP48024 not sure which or both is the chp prod number and the schematic
Channel: BIOS Requests ONLY!
by CdDvdFlashI need help to find the datasheet for a:
Nippon Chemi-Con
CE NM 85c
180V 680uF
30mm diameter, 51mm high, 10mm leg spacing
on the top of the cap is a plastic top with "43SKH"
Im trying to find the ripple current, Ive looked all through here:
https://cdn.badcaps-static.com/pdfs/...d92625445c.pdf
but it does not have anything for SKH or CE NM-
- Loading...
