Question about bad capacitors
  • Sandokazi
    • Dec 2011
    • 5
    Not sure if this is the right place to post / ask this but....anyways....earlier this year my computer died. No display / post / fans spun but that was all. Checked alot of stuff at the time and could'nt figure it out so I just gave up.
    Well, I recently opened it back up and after a little research found that 2 of the capacitors were bad, one was slightly bulging at the top and the other was bulging plus had some black gunk on the top.
    My question is if it'd be worth trying to replace them. The motherboard wasn't a very expensive one, and I'm kinda hesitant because I tried the CPU that was in it in another computer and it didn't work so I think maybe it might've killed it? Also I noticed on the back of the motherboard where the CPU socket is some spots in the pins are miscolored.
    Again, I'm sorry if this is in the wrong place, made this account to ask this question. Thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Question about bad capacitors
    Absolutely yes, replace the 2 that are bad. I got a socket 775 Asus motherboard with one obvious bad cap. It wouldn't post and after changing the one, it is working fine.
    Having said the above, capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    So try replacing the 2 obvious bad ones and retest. If it works, you may consider changing all the caps if you think the motherboard is economically worth it.
    --- begin sig file ---
    --- end sig file ---
    • Sandokazi
      • Dec 2011
      • 5
      Thanks for the reply. I'll definitely give it a shot and replace them, I think mostly what I'm worried about is if it could've killed my CPU. Had ordered another knowing the one I have is dead but kinda nervous to try it out and have it die : /
      • retiredcaps
        • Apr 2010
        • 9271
        Your CPU might be fine. If you put the CPU into another PC and it didn't work, then it could be that the other motherboard doesn't support that CPU in the BIOS?
        • Sandokazi
          • Dec 2011
          • 5
          Completely forgot to check when before I tried it....scared me for a sec, lol...But after looking around a bit the particular mobo does seem to support the CPU
          Edit: Nope, I'm an idiot...it does'nt /facepalm. Okay, with the bad capacitor's I'm guessing the CPU wouldn't get any power? Prolly a dumb question but as stated before...I'm an idiot, lol
          • retiredcaps
            • Apr 2010
            • 9271
            It depends where the cap is. On my motherboard, the bad cap was right next to the southbridge chip.
            All the caps on the motherboard play an important role. Some work with the DRAM, some with the CPU, some with southbridge, etc. Your system won't POST due to any number of the above reasons + many more.
            • Sandokazi
              • Dec 2011
              • 5
              Alright, well I'll give it a try. Thanks for the info
              • Hitto
                Slightly Bulging Capacitors
                by Hitto
                Would you consider a slightly bulging capacitor defective if it measures perfectly and it is brand-new? To be honest, they are all equally like this: vent is not totally flat but they have very low E.S.R. and VLOSS is negligible.
                So, everything seems perfect apart from the vent looking a bit "strange". They are genuine capacitors, BTW.
                The bad thing is that they are 400V capacitors so testing them just to check how much they last would mean using them on the primary of a power supply, which means the risk of damaging the whole circuit.
                What do you...
                12-23-2024, 05:08 PM
              • dragon3x
                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                by dragon3x
                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                power on.
                Here are some examples :
                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                switching supply area).
                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                than 6.3 V.)
                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                I replaced capacitors with aluminum-polymer.
                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • Cama
                Solar Inverter - SMH-II - 2 missing capacitors
                by Cama
                I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                My model is : EASUN SMH-II 7 KW
                Mother Board : P/N 18947-002401250250
                Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                Thank you...
                09-12-2025, 02:50 AM
