fcon capacitor datasheet
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    hi chaps,looking for a data sheet for these caps,and cant find one !,looking to replace 4 470uf 16v fcon gl 105 degree caps that are leaking with panny fc series for a lcd tv main av board that are leaking,but cant check on ripple current and other specs,google has returned nothing,hope you can help
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Re: fcon capacitor datasheet
    http://www.fcon.com.cn/
    • mariushm
      • May 2011
      • 3799
      fc will probably not be good enough. go for panasonic fm/fr or nichicon hm/hn.
      I'm currently replacing 1000uF 10v gf series on a Gefore mx 400 video card with 1000uF 16v FM series - didn't even check the specs on fcon website but it must be better....
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        thanx to rob found the spec for the fcons, the fcons ripple at 16v 470uf runs at 600,the panny fc are 16v 470uf ripple at 995 so thats good,i do like the panny fm but only have the fc at the moment in that uf and voltage
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
