SMT Poly lead length?
  • asand1
    Oregon, USA
    • Oct 2011
    • 123
    Do SMT poly caps have sufficient lead length to re-use in a through hole board, minus the plastic base?
  • mockingbird
    • Dec 2008
    • 5488
    Re: SMT Poly lead length?
    Yes.
    But SMD cap leads are kind of flimsy.
    • CapLeaker
      Poly VVX-250 VOIP POE problem not booting fix
      by CapLeaker
      I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
      Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
      11-25-2023, 10:46 AM
    • chj4591
      gddr5 ball lead?
      by chj4591
      gddr5 memory ball lead size?
      0.4mm 0.45mm 0.5mm​
      05-05-2025, 10:42 PM
    • Eh546
      Beginner, practicing to unsolder on a lead free xbox 360 board, it is hell.
      by Eh546
      Don't hesitate to tell me what i do wrong and if you have any tips and tricks, because i want to learn and improve.
      I have a 60w iron that can go up to 450c, cone tip, i usually set it at 400. I applied flux on solder, tinning the tip then applying new lead solder to the joint so that it can mix with the lead free and lower the melting point, then i tried to suck up the melted solder with the solder sucker. But that didn't work since the lead solder doesn't seems to mix with the lead free one. I also tried applying flux to a wick and the board, then tinning the tip of the iron and...
      05-24-2020, 06:59 PM
    • Stanley1843
      BEST 505 Vs Mechanic Brand Reballing Balls with Lead
      by Stanley1843
      has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
      06-22-2024, 11:06 AM
    • jasakl
      Panasonic Toughbook HDDs with hard drive encryption - how to reuse them?
      by jasakl
      Dear community,
      i have searched the internet but i dont found a working solution for my problem:
      I have about 150 hard drives (mostely from hitachi 160gb HTS543216L9SA00) from Pansasonic CF-19 MK3 Notebooks.
      All devices had a BIOS Password and HDD encryption enabled.
      Now i try to reuse the HDDs, but i cant format them. I already tried windows Diskpart with argument "attributes disk clear readonly" but it says "cant delete" and i tryed several partition and low level formatters (like partition wizard, AOMEI and Easus).
      But all of...
      05-01-2024, 02:41 AM
