What brand are these caps?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Can't figure it out, all I can see is the symbol, SC. Are they Sacon or something like that? I know they suck nuts cause they are in a blown to hell Raidmax, I just want to know the brand name for future reference.
  • mariushm
    • May 2011
    • 3799
    Re: What brand are these caps?
    here's who it is: http://goo.gl/eF7Zo
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      So in other words, Chinese Shit....ohhhh I get it, that's why it's CS
      • c_hegge
        • Sep 2009
        • 5219
        • watchmaker
          • Aug 2011
          • 6
          • Ukraine
          *ROFL*
          *COOL* I love it too...
          • Evil Lurker
            Warranty Voider
            • Feb 2011
            • 454
            Hmmmm member since sept 2011... he learns quick lol.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3113
              No, CS means "12 Kuang Jin Enterprise Co, Twenty Photon Electron, LTD."
              Come on, it's pretty simple.
              • Rulycat
                • Apr 2010
                • 724
                Could it also mean Chhsi?
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Hahaha, your posts made me laugh. But sadly, that wasn't the worst thing in the PSU. The PCB around the second transformer is highly discolored and the PSU won't boot up hooked up to a computer (thankfully)
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
                  • Foetuss
                    Gigabyte GA-6OXT :: caps question
                    by Foetuss
                    Good evening
                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                    But I was also suprised about the bigger boys, which are 330µF 25V.
                    Could it be they used 25V caps because they were cheaper / available at that time?...
                    02-11-2025, 12:22 PM
                    by momaka
                    03-12-2025, 03:42 PM
