Okay, not sure where to post this.
  • PCdweeb
    • Nov 2011
    I have a Hannspree 27.5ish inch LCD monitor hooked up to my PC, of late it has been shutting down when the PC goes into sleep/hibernation mode.
    Then it won't turn back on, no indicator lights...nothing. Yet oddly, if left alone a few days...it just magically starts up again.
    At first the orange indicator light comes on and flashes, then goes solid, then to blue.
    It will work fine for a week or longer, as long as it doesn't go into the sleep/hibernation mode again. : P
    I am not very PC savvy to be honest, but I try to be a diligent researcher at the very least...and after searching and stumbling onto this site, I'm hopeful.
    You guys seem to know about this stuff and I am eager to get some advice on how to proceed...the more I know, the less I tend to be taken advantage of when getting things repaired.
    Single female repair syndrome. >.<
    Anyway, so far I am wondering if maybe the capacitors are not recharging...whatever that truly means, but it seems as though the monitor revitalizes itself after time.
    ...which seems pretty odd. : P
    I also noted that jiggling the HDMI cord on either end, seems to at the very least make the orange indicator light come on for a split second.
    ...so initially I thought that maybe the adapter or cord had gone bad.
    Any suggestions?
    Not looking forward to getting it repaired, too broke to deal with that...but I have an Aspie in this house that literally breathes air through the PC it seems, and he is driving me nuts while it's down for the count. >.<
    Thanks in advance for whatever time and knowledge you can share. ^_^.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Okay, not sure where to post this.
    Originally posted by PCdweeb
    Any suggestions?
    1) This should have posted in the troubleshooting computer display forum.
    2) You can start by posting a clear focused picture of your boards with the following composition.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    Please do not post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    3) Your problem could be bad capacitors. Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    --- begin sig file ---
    --- end sig file ---
    • PCdweeb
      • Nov 2011
      Ummm, I am flattered that you even think I know how to take apart my monitor. LOL
      ...nevertheless know what pictures to take and of what. >.<
      Oh, and I apologize for placing it in the wrong category.
      Perhaps this was a bad idea, this place may be far too high tech for my extremely layman mind.
      ...but thank you for your time just the same, retiredcaps. ^_^.
      • rumpumpel1
        Lenovo X13-Yoga Gen 1: hibernation problems
        by rumpumpel1
        I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
        11-03-2024, 12:31 AM
      • binary0101
        Asus X453SA No Display - Charging Indicator Blinking
        by binary0101
        Greetings
        I got an Asus X453SA for repair
        Symptom : no display, with charging indicator blinking, with or without battery. Power indicator is steady. When battery plugged in, the current consumption jumps, but the charging indicator is still blinking.
        Here is the measured power sequence :
        +3VA_EC +3.3V
        EC_RST# +3.025V
        +5VSUS_ON +3.307V
        PWR_SW# +2.982V
        3VSUS_ON +3.307V
        SUS_PWRGD +3.386V
        +1.05VSUS_PWRGD +1.061V
        1.8VSUS_EN +1.873V
        VSUS_PWRGD +3.383V
        PM_PWRBTN# +1.830V
        PM_RSMRST#...
        02-01-2023, 02:33 PM
      • bembeno
        HP 15-e98se No power and The charging indicator LED is dim and flickering in white
        by bembeno
        HP 15-e98se No power and The charging indicator LED is dim and flickering in white when i checked pl9,pl10 i found 2.8 volt when i checked pq35 i found that Drain = 19 v source = 2.8 and the gate = 2.6...
        10-12-2025, 09:18 AM
      • roy.zhero
        Sharp LC50LE752E no picture and backlight, indicator light is lit
        by roy.zhero
        I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
        When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
        When I hold the force-on-combination it will turn on. It then shows a perfect...
        09-20-2020, 01:57 PM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
