how to test capacitors on motherboard with a multimeter
  • wilywizzzz
    • Jan 2011
    • 10
    Friend of mine gave me motherboard not working.
    I can't see if any of the caps are bad cause he washed it with hot water.
    Is their any way to Use a Multimeter to Test a motherboard caps.
    Thank you for all your info.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: how to test capacitors on motherboard with a multimeter
    You can tell a little bit [if you remove the cap] but not enough to know if the cap is good.
    Obviously if your meter has a capacitance function you should check that.
    DC check....
    Put the meter on ohms and connect, let cap charge from the meter. [#s will stop going up]
    Reverse leads, watch cap discharge then charge again. [#s will go down then up.]
    Reverse leads again, watch cap discharge then charge again.
    - Very hard to do with a digital meter. An analog meter is better for that because you can watch the needle. Digitals usually just look like numbers flashing. It helps w/a digital to change/experiment with the ranges to find one with a slower charging rate.
    If no charge and discharge the cap is either open or shorted and the reading will tell you which.
    ESR is an AC property.
    The DC check can be fine but the ESR still be totally screwed.
    Caps with high ESR can make a board unstable or not run at all.
    If you don't have an ESR meter
    - and since you have to pull the caps to check them with a multimeter anyway
    - it's best just to replace any brand/series cap with known problems.
    Mann-Made Global Warming.
    - Dr Seuss
    • wilywizzzz
      • Jan 2011
      • 10
      Thank you very much.
      Enough info being said.
      • JagWar
        • Sep 2011
        I've seen multimeters which can measure capacitance, and I was tempted to buy one from lowes, but i didn't understand the range of capacitance it could detect. it stated it could detect in the nano range up to 4 mf- now is m for micro or milli? Sorry if this is a dumb question but if it were micro i would think they'd use mu. (some stores state 100mf on their sites to stand for micro farad, hence my uncertainty- I think it was this model specifically: http://www.amazon.com/Ideal-61-312-R...6414091&sr=8-2)
        Does anyone have a suggestion for a not too expensive multimeter that can detect capacitance from 10 to 1000 μF ?
        Thanks!
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          1 Farad = 1 F
          1 Farad = 1,000 mF [Millifarad ]
          1 Farad = 1,000,000 uF or MFD [Microfarad] - Some incorrectly use MF [w/a capital M]
          1 Farad = 1,000,000,000 nF [Nanofarad]
          1 Farad = 1,000,000,000,000 p [Picofarad]
          Dunno where they got the 4mf from.
          Link below shows it's ranges are: 40.00nF / 400.0nF / 4.000uF / 40.00uF / 400.0uF
          http://www.idealindustries.com/prodD...?prodId=61-312
          I use a separate meter for capacitance. [Run like $20-$50 on eBay used.]
          DMM's I've seen with a capacitance function have pretty lame capacitance functions IMHO.
          Really need one that's good to at least 5000uF to cover those 4700uF that are common place.
          Not many [if any] DMM's go up to that.
          - Dr Seuss
          • ipman
            • Jul 2011
            • 159
            A separate capacimeter, or better an LCR meter will be better than just a DMM.
            But please note that it will not measure capacity on-circuit most of the time.
            • JagWar
              • Sep 2011
              Thanks for the explanations and advice!
              • saf
                • Sep 2011
                • 9
                You can certainly check if the surface mount cap is good or bad. Connect the negative lead to ground and the positive to ends of the cap alternatively,
                1 end of cap will give a beep sound and the other end will give some value this means most probably, the cap is fine, but.... both end beep or both end value or no beep at all means the cap needs replacement.
                But still, ESR meter is must when you are playing around with capacitors.
                • chth96
                  by chth96
                  03-09-2024, 10:03 PM
                • dj8452000
                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                  by dj8452000
                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                  02-18-2025, 08:28 AM
                • dragon3x
                  by dragon3x
                  power on.
                  Here are some examples :
                  switching supply area).
                  than 6.3 V.)
                  03-21-2025, 02:46 PM
                • varkatope
                  Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                  by varkatope
                  Hey there, retro fans.
                  I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                  12-15-2024, 09:48 AM
                • blablaro
                  Philips PSU (715G7350-P01-000-002S) No stand by light (0V)
                  by blablaro
                  This is the source from a Philips TV 43PUH6101 that suddenly stopped.
                  I know it's the source since I have ~ 0 volts on outputs 12VA/16VA, 12V/16V, +3.5/+5V
                  For the latest weeks I've been trying to figure out the problem with this. I've ordered all kind of mosfets, a capacity meter and other things to try to figure out the issue with this PSU. My wife thinks I'm crazi but I want to repair it
                  Initially, when I started the testing with the multimeter on diode mode (220 V on):
                  - discovered that was Q9101 shorted (or I shorted it)
                  09-24-2025, 10:21 AM
