I'm speaking of the small black Ketuo 6.3v 470uf caps. this small thermostat has 5 of them
and they are all slightly leaning. The larger caps in the background were just replaced due to leakage.
On another note I'm having a hard time tracking down ones of the same physical size to
replace them with just in case they are failing. I checked digikey and Mouser with no luck.
They seem to be around 6mm in width and 8mm tall but due to the confined space I think
10 mm is the tallest that will fit.
The closest I have found is here but brand unknown..
