Samsung 225BW Monitor Caps
  • primoadamp
    • Jul 2011
    I need to replace two bad caps in my monitor.
    The two bad caps are the same: 820uF, 25 volts, 10x20mm, radial
    There are multiple caps I found on mouser.com but which ones do I need?
    Low ESR? High Frequency?
    I found this one. Could this be it?
    http://www.mouser.com/ProductDetail/...2%252baxzw0%3d
  • japlytic
    • Oct 2005
    • 2086
    Re: Samsung 225BW Monitor Caps
    Welcome, primoadamp!
    You are correct about these capacitors needing to be low-ESR (low-ESR usually means they are high frequency units) such as Nippon Chemi-Con KY (or KZM if you can get them) or equivalent.
    • primoadamp
      • Jul 2011
      So the low esr caps are the ones I need for this monitor?
      • ipman
        • Jul 2011
        • 159
        I suppose the original ones were Capxon.
        I exchanged similar ones with 1000 microfarad ones made by Sancon which, while not being Low-ESR, had lower ESR value than the original Low-ESR Capxons. Works fine anyway, because they are just filtering caps.
        Pay atention to temperature rating, they must be rated at 105 degrees celsius because they are quite close to a double-diode heatsink.
          09-07-2024, 05:50 AM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
          by momaka
          03-15-2023, 10:17 PM
          by momaka
          03-12-2025, 03:42 PM
          09-06-2024, 11:40 PM
