Stress tests and burn-in utilities
  • Stever
    • Jan 2004
    I read at https://www.badcaps.net/repair/ the following:
    When it first arrives I connect it to my test jig, and run it through a battery of stress tests before I do ANYTHING to the board. ...
    I then replace them with high-quality NEW capacitors. ...
    Using several popular burn-in utilities, I run it through a 72-hour constant burn-in cycle. ...If it can pass my testing, there's not much more that one can dish out that it can't handle beyond the motherboard's design specs.
    I'd like to know what stress tests and burn-in utilities are recommended for determining if the board has a problem.
    Thank you,
    Steve Smith
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Welcome to the forums!!
    I use a testing/burn-in utility called The Troubleshooter v7.02 for the first day. I then boot it off a hard drive loaded with XP Pro Corporate Edition and run SiSoft Sandra Professional 2004 (the FULL version with burn-in utilities) for the remaining 2 days. During the entire 3 day process, the motherboard is in a confined space with limited air flow. This makes things run hotter tham most normal PC conditions, adding even more stress.
    If it passes that abuse with out hiccuping, it's safe to assume that the board has been repaired. Typically, if a board is going to fail, it will usually do so within the first few hours of testing.
    I hope that clears things up.
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • brandon.bragg
      Full ThinkPad Maintenance Utilities / Golden Key for P15 Gen 1
      by brandon.bragg
      I’m working on a Lenovo ThinkPad P15 Gen 1 (Machine Type 20ST-004DUS), and recently replaced the motherboard (planar).
      I successfully booted into the Golden Key U1 Tool (v3.5.78), and it launches ThinkPad Maintenance Utilities v1.20(x64) — but my version appears to be missing the full Set System Identification menu (it only shows Add/Read/Delete S/N options).
      Here’s what I’ve already done:
      • The EEPROM has been initialized successfully
      • The U1 tool loads and detects the ThinkPad fine
      • The current MTM/SN/UUID fields are blank
      • When trying to enter
      10-31-2025, 04:32 PM
    • Inforgalaxie
      Overheating in Stress Test
      by Inforgalaxie
      Hello i have a problem, i have a laptopt Dell E5570 that in stress test without the battery it works good and not turn off.
      But when i conect the battery and made a stress test the cpu temperature go to 95º and turn off. I also was testing with a new battery and the problem is the same in stress test turn off with big cpu temperature (95-100º). What can be this?
      12-13-2023, 03:24 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • diozone
      BIOS utilities platomav
      by diozone
      Good evening everyone, I'm stuck with BIOS utilities https://github.com/platomav/BIOSUtilities
      I'll send you a screenshot.
      I open the command prompt
      I type main.py
      It displays
      Enter input file or directory path: C:\Users\wwesu\Desktop\GX531GV-F1.306
      Enter output directory path: C:\Users\wwesu\Desktop\GX531GV-1.306
      and I don't have any files at the end
      Could you help me fix this problem?
      Thank you​...
      03-30-2025, 10:32 AM
    • Maniackk
      Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
      by Maniackk
      I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
      The cooling system has been cleaned, thermal...
      09-03-2025, 09:32 AM
