BIOS utilities platomav
  • diozone
    • May 2023
    • 27
    • france
    Good evening everyone, I'm stuck with BIOS utilities https://github.com/platomav/BIOSUtilities
    I'll send you a screenshot.
    I open the command prompt
    I type main.py
    It displays
    Enter input file or directory path: C:\Users\wwesu\Desktop\GX531GV-F1.306
    Enter output directory path: C:\Users\wwesu\Desktop\GX531GV-1.306
    and I don't have any files at the end
    Could you help me fix this problem?
    Thank you​
  • LEO037_2029_
    BIOS_LEGEND
    • Nov 2023
    • 83
    • Argentina
    diozone try this = Enter input file or directory path: C:\Users\wwesu\Desktop\GX531GV-F1.306
    try and feedback.. godd luck
    • LEO037_2029_
      BIOS_LEGEND
      • Nov 2023
      • 83
      • Argentina
      dont post the same name in directory output just select desktop and press ENTER. just look in the picture and i attach and TRY .
      good luck
      • diozone
        • May 2023
        • 27
        • france
        Thanks for your help, LEO037_2029_
        Unfortunately, it's the same thing.​
        • imranromi
          • Jan 2015
          • 1292
          • Pakistan
          I type main.py
          It displays
          Thank you​
          Upload here exe file will try to extract
          • diozone
            • May 2023
            • 27
            • france
            Do you have a link? Thank you.
            • imranromi
              • Jan 2015
              • 1292
              • Pakistan
              Which file you want extract send me here i test
                • 22293
                Looks like the Asus service bios at post #4 in this thread - https://www.badcaps.net/forum/troubl...x355gv-request
                • diozone
                  • May 2023
                  • 27
                  • france
                  Yes, it's the same BIOS. I just want to get this program working to learn how to reset BIOSes.
                  If anyone can unzip it, I'd be grateful.​
                  https://www.badcaps.net/filedata/fetch?id=3535427
                  • imranromi
                    • Jan 2015
                    • 1292
                    • Pakistan
                    Here
                      • 22293
                      The extracted update posted by imranromi is 12MB, not a full bios image. What`s wrong with bios posted by hoaca388 at post 10 ,didn`t you try it, he`s even copied your DMI to it https://www.badcaps.net/forum/troubl...43#post3556643
                      • reformatt
                        Create MEAnalyzer executable from Github Python Scripts
                        by reformatt
                        Each new release of ME Analyzer only has the scripts but no executable file. It's handy for me to just run the exe in Windows, so came up with the following guide for those that might want it. Didn't see anywhere else how to do it, apologies if it is documented somewhere and I've just missed it.
                        ME Analyzer – create Windows executable from Python script from GitHub
                        1. Install Python 3.xx from https://www.python.org/downloads/ – select to add Python to PATH during installation. Current version is Python V3.11.
                        2. Open an elevated Windows Command Prompt...
                        02-06-2023, 07:33 AM
                      • BMCappelletti
                        Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                        by BMCappelletti
                        Hi everyone.
                        Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                        Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                        Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                        02-18-2025, 12:22 PM
                      • alfredposadas09
                        cant enter recovery mode lenovo c13 yoga chromebook
                        by alfredposadas09
                        cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
                        11-09-2024, 10:09 AM
                      • tobeend
                        Bypass mdm macbook m2 ventura
                        by tobeend
                        1. RESET MACOS WITH IPSW
                        a. Power off MacBook, press and hold the power button to enter Recovery
                        b. Open Disk Utility, remove Macintosh HD
                        c. Reboot, connect to the network to Activate Mac.
                        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                        e. Release the other keys, but keep holding the Power key for another 10 seconds
                        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                        05-26-2023, 07:18 AM
                      • brandon.bragg
                        Full ThinkPad Maintenance Utilities / Golden Key for P15 Gen 1
                        by brandon.bragg
                        I’m working on a Lenovo ThinkPad P15 Gen 1 (Machine Type 20ST-004DUS), and recently replaced the motherboard (planar).
                        I successfully booted into the Golden Key U1 Tool (v3.5.78), and it launches ThinkPad Maintenance Utilities v1.20(x64) — but my version appears to be missing the full Set System Identification menu (it only shows Add/Read/Delete S/N options).
                        Here’s what I’ve already done:
                        • The EEPROM has been initialized successfully
                        • The U1 tool loads and detects the ThinkPad fine
                        • The current MTM/SN/UUID fields are blank
                        • When trying to enter
                        10-31-2025, 04:32 PM
