Unknown polymers
  • Behemot
    • 4845
    • CZ
    Unknown polymers
    Found some polys on dead ASUS P5L 1394 mobo. They are labeled 680uF 4V FL with black stripe left from this text, no color marking or manufacturer logo. Who makes these? If you cannot recognize it, I will provide image later
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Unknown polymers
    They aren't poly.
    They are Panasonic FL.
    Should see the [M] for Matsushita somewhere on them.
    That's the logo.
    The brackets around the M are different than the (M) that means +/-20%.
    Mann-Made Global Warming.
    - Dr Seuss
    • Behemot
      • 4845
      • CZ
      No no, there is no Matshishita logo, I would recognize it :-) They even use the can typical for polymers, with no vent or so.
      • mockingbird
        • Dec 2008
        • 5484
        Yes, there are polymer FL, I have seen them.
        • Behemot
          • 4845
          • CZ
          Were they normally manufacturedd, or is it custom production? You probably don't have datasheet…
          • lti
            • May 2011
            • 2550
            I've seen these before, but the ones I saw had an X-shaped vent.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Panasonic FL are electrolytic.
              Not all lytics have vents.
              It's not uncommon for those odd ass 680uF 4v lytics to not have vents.
              OST has been doing that for ages.
              I've seen Panny FL's like that.
              I've seen Rubycon ZL like that. [By RAM slots on some Dell boards.]
              And as recently discovered in another thread with TMV, Chemicon does it too.
              Not all that unusual...
              - Dr Seuss
              • POM_MJ
                • Aug 2009
                • 228
                Correct.
                link to reference V-FK, V-FP presentation.
                http://www.ttieurope.com/docs/IO/175...esentation.pdf
                | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
                | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
                | 2xWD7500AYYS | 2xHD322GJ Raid0 |
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Interestingly I was just thinking about this then someone posted a nice pic of it.
                  Here:
                  https://www.badcaps.net/forum/showth...374#post165374
                  See those round holes?
                  Those are basically weakly glued in rubber plugs in through-holes.
                  That's another way they accomplish pressure relief but it's usually done on much larger caps.
                  - Dr Seuss
                  • lti
                    • May 2011
                    • 2550
                    I posted those pictures. I just thought that those caps were either very old or very poor quality.
                    Also, I have a 2200uF 35V Nichicon VX that has the same pressure relief, but it is an axial cap so there is no vent.
                    • Behemot
                      • 4845
                      • CZ
                      OK, I think I will canibalize them, but sacrifice one piece and have a look inside to discover what they really are
                      • Behemot
                        • 4845
                        • CZ
                        Well I did not open any polymer before, but did liquid electrolytic and this seems as one to me. The paper is wet from electrolyte.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Those are indeed Panasonic FL and as I told you they are lytics, not polymer.
                          I didn't know you were looking at that style marking on SMD caps.
                          Matsushita logo is normally only seen on caps with sleeves.
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Sleeves are only a way to mark caps. That's all.
                            Doesn't tell you what technology they are.
                            Ages ago MOST caps were marked by direct printing on the end [or side] like like that FL you took apart.
                            Polymer caps didn't even exist yet.
                            Then they developed heat-shrinkable plastics and started using sleeves to mark caps because it was cheaper and easier in an assembly line situation.
                            Since then advances in printing technology and automated equipment has made direct printing cheaper than and as easy as using sleeves -but- there are scads of already existing cap sleeving equipment that is already paid for or for sale cheap.
                            Having a sleeve or not is NOT a reliable way to tell if you are looking at a lytic or a poly.
                            - Sanyo OS-CON Polymers typically [historically] have sleeves.
                            - Nichicon HD series radial Electrolytics without sleeves show up all the time.
                            [I see HD like that off-on in all ages of equipment. I suspect one of Nichicon's factories simply doesn't sleeve the HD series so some % of their HD production is sleeveless but it could be some kind of special order too, not sure.]
                            - There are other examples if you look around...
                            Having a top vent or not isn't 100% reliable either.
                            - If they consider it small enough [or the chemistry is such that] it isn't likely to explode from gas formation they won't use a vent.
                            - Hybrid Polymers [aka Functional Polymers] often have vents because in addition to the polymer they still have some wet electrolyte.
                            - Some SMD's have a vent method built into the base which you will never see.
                            - I've also seen mechanical drawings of cap construction that for the small [5-6mm] cans showed vents pressed into the sides of the can where it would be under the sleeve. The idea is the gas will pass between the sleeve and the can.
                            -- So, there's a few times when no vent on top doesn't mean no vent at all.
                            The Panny FL you just dissected breaks all the 'rules'.
                            That's because they aren't actually rules, they are just typical.
                            - Dr Seuss
                            • Verlengsnoer
                              Bios splash/logo change
                              by Verlengsnoer
                              at firs, i hope this is the right place to post my question.
                              Im looking for a tool to change the bios logo.
                              everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                              i know that HP has a build in option to change the splash logo.
                              but i want to change the manufacturer logo to an own logo.
                              I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                              10-28-2022, 09:52 AM
                            • Echoo
                              Fujitsu D757 sff desktop pc bios logo reset
                              by Echoo
                              Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
                              11-25-2024, 01:54 AM
                            • smarty
                              Can anyone identify PCB logo?
                              by smarty
                              Can anyone identify logo shown below?
                              The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
                              I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
                              Neither ChatGPT nor Copilot know the correct answer.
                              TIA
                              09-10-2024, 11:48 PM
                            • q2v5
                              Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                              by q2v5
                              Lenovo T480s
                              Model 20L8-S3TE00
                              Board ET481-U10
                              Chip MX25L12873F
                              Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                              2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                              The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                              08-15-2024, 10:40 PM
                            • p.puhakka
                              Fujitsu Esprimo K557/24 allinone desktop, boot logo
                              by p.puhakka
                              Hello forum!
                              I have received a lot of help here, regarding bios modding. Very thankful!
                              Now I have a lot of Fujitsu K557 desktops, and those have custom bios logo/custom splash screen, and I need to change them to the original Fujitsu logo.
                              I am looking for the easiest way, because I have about 40pcs of them, and I think there is some "official" way to do this.
                              I have tried a lot of Fujitsu tools, which can inject the logo to the bios file, but no luck.
                              Any suggestions? Thanks!
                              06-06-2024, 11:24 AM
