Anyone know, where to buy them? Europe preffered, as I'm from it...
The story go like this. Im fanless maniac. I also like to OC a little Recently I have some stability problemy on clocks, where things worked well before. And I just realized what my problems was - the caps blown with loud explosion on my mobo, so now Im in process looking for 1500uF 16V low ESR caps.
I also found out, that the caps are made by Chemi-con and their type KZG aren't even optimal for mobos! KZG versions are low ESR/impedance ones, correct ( - compare to - ) yet they did not handle well impulse currents. Okay, they even claim "Super low ESR/impedance", but the sheet did not show any values.
Now check this out - they also made considerably more pricely LXY/LXZ versions of caps, specificaly engineered for long-live with impulse currents AND low ESR as well, as the KZG ones has!
Sure, they cost 250% of the KZG line, so DFI use the cost-optimized version and the results are that after 1,5 years they explode...
Not to mean the time degradation - now is pretty clear for me, why 2700Mhz was not a problem at start, yet recently it was complete lock-up. 2600Mhz was stable last winter, yet not this winter and the list could go so on and so far - no wonder, there are 6 (!) 100uF caps missing only in the PCI section a rather large cap close to the 12V support is missing too (that's wher the two ones that died was) and the 4 caps close to the main PSU connection are nowhere near to be found as well - not to mention what is missing into the CPU socket and close to the ram voltage regulators...
So much for DFI.
So, anyone know, where to get quality stuff?
So much for DFI.
