Bad Capacitor Dissection
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Havent we all wondered what a dissection of one of these crappy caps would look like? Well I thought I'd find out....
    The bad capacitor used for this was a JPCON 2200uF 6.3v low-ESR cap removed from an Abit KA7-100 motherboard.
    Before the 'surgery', this capacitor looked like just about all typical bad capacitors, bulging from the top and the canister seal was protruding from the base. I carefully cut the canister open with a razor blade, so not to further damage the insides. Upon pulling out the paper innards, I noticed that the paper dielectric material was severely scorched and completely dry. I then began to unwrap it to gain access to the two metal plates and the paper filling just crumbled and fell apart in my hands. Its brittleness and crumbling reminded me of very old newspaper. When I finally got to the plates, they were slightly melted and disfigured, as the capacitor had obviously gotten extremely hot.
    Ok, this next capacitor was a good one to use as a demostration of what it SHOULD look like... It was a perfectly healthy Nichicon 2200uF 16v low-ESR.
    You can see the obvious color difference! Everything is completely intact, and was soaking wet with electrolyte! You will note that the paper filler and the metal plates are all in one piece and intact.
    Ok, if you've ever wondered, now you'll know...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    i have seen caps that the plates were reduced to powder.
    btw the paper is only a blotter to hold electrolyte .
    the dielectic is the grey oxide coating you see if you peel the 2 plates apart.the paper probably helps during the forming process to prevent shorting.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      powdered plate anyone?! HEH.... This one wasn't that bad, nor have I actually seen one that bad with the exception of a 1959 Philco Predicta television I recapped some years ago...
      I did remove the plates on these caps to try and get a pic of the dielectic, but my crappy camera wouldn't get a clear close-up, nothing but fuzz.
      The Nichicon cap's filler material wasn't paper, but rather a cloth-like material, where the JPCON was clearly lower quality, using paper material.
      I figured folks got the idea...
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        predicta huh?
        i collect and restore old radios tv's boatanchor recievers and ham gear.
        check out this.
        http://www.audiokarma.org/forums
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          HMM I have a MASSIVE collection of antique televisions, including 3 predicta's. They're all between the years of 1950 and 1960. If interested, let me know. I can get some pics. I'd like to sell the whole lot, they're taking up too much room in my house since I sold my store.
          Team : 49813
          Join in!!
          Team Stats
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            my main interest is early round screen color.
            but am interested in all old sets.preferably unrepaired.
            hell i just picked up another heath gr2000.
            had a bad cap in the remote board.
            funny how it now has a better picture than my neighbors 2 year old zenith i just repaired.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              funny u mention old round screen color's... i had 3 RCA's... they were the strangest and ugliest critters, but worked... most of mine are unrepaired... i polished them up and displayed them. at the time the last thing i had time for was more hobbies.
              Team : 49813
              Join in!!
              Team Stats
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                got a ctc16 on the bench now.
                needed a degaussing thermister and vdr and a few resisters in the 3.58 and burst amp.
                looks good on the test jig and heats the room too.
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • Agent24
                  Dick Smith Q-1760 linear power supply filter capacitor question
                  by Agent24
                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                  It has at least one problem.
                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                  I have already ordered a replacement potentiometer, so that's not an issue.
                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                  All are CapXon...
                  10-21-2025, 05:39 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                  HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  09-12-2024, 03:28 PM
