I know this has been beaten to death but...
  • drmikedvm313
    • Jan 2011
    I've been doing some reading all over the place and just wanted to make sure I'm not getting in over my head before I attempt this. I'm generally very handy and I'm not too intimidated thus far so I'm gonna give this a try....
    I have a Samsung 40" LCD HDTV that sounds as if it is demonstrating the symptoms of the plague (prolonged startup, clicking, pink pxels on screen). I plan on contacting Samsung tomorrow to see if I can convince them to do an out-of-warrantee repair at no cost as it seems that some people have had success doing...but I want to have a backup plan in place and personally relish the idea of trying to fix this on my own if I have nothing to lose
    So if I understand this correctly, I need to open up the back panel of the TV and inspect the capacitors on the power supply. I believe that I'm probably going to simply replace any and all capacitors I find regardless of their appearance just to be safe. i plan on taking out the caps and taking them to a local store or purchasing suitable replacements online.
    When I get replacements, should I use caps rated for a higher voltage? It seems to me that the reason that most of these failed was because of poor manufacture quality of the component itself, and not actually in the way the component was used.
    Please note, I have never soldered anything in my life, but this sounds like fun and if I have nothing to lose, I want to try it. I may even learn something in the process
    Materials needed:
    Soldering iron
    Solder (appropriate type)
    Desoldering wick
    Caps
    Anything I'm forgetting?
    Thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: I know this has been beaten to death but...
    Prolonged startup could be caused by bad caps.
    Yes, replace them all. A list of good quality low ESR capacitors can be found at
    https://www.badcaps.net/forum/showthread.php?t=2280
    Make sure the replacement capacitors fit (diameter and height).
    Stay with the same voltage. Some manufacturers make shoddy caps and that is why they fail.
    A really good soldering video is on youtube from CuriousInventor. See
    http://www.youtube.com/watch?v=I_NU2ruzyc4
    Materials needed:
    Soldering iron
    Desoldering wick
    Caps
    I prefer a solder pump versus the wick. You will probably need a 30W or 40W iron.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      And I forgot this forum has an excellent guide on soldering at FAQ section
      https://www.badcaps.net/forum/showthread.php?t=485
      • Agent24
        I see dead caps
        • Oct 2007
        • 5095
        • New Zealand
        If you have never soldered before, I would advise that you should do some practice runs before you do anything on your TV.
        Make sure you look after your iron, keep it tinned and clean. If it gets dirty and damaged you won't have much fun at all.
        -David VanHorn
        • pni
          Vorwerk vk 200 death
          by pni
          Hi I have a vorwerk vk200 it didn’t turn on nothing. I checked the main board…and on the MiP2f2 I have a short on the vdd pin and the cl pin that should be not good… if I remove the ic the short on that pin stay still…. So I checked the mosfet g10t60 and also they are good. I checked the diode schottky d06e60 also their look good at the first but if I put the multimeter on both the anode I have short circuit….that is not a good I think… so I remove one by one the diode and when they are out from the board the anode aren’t in short but in the main board there is still a short on the...
          11-03-2025, 06:17 AM
        • Gjackson
          Ps4 Pro long blue light of death
          by Gjackson
          I have an NVA-001 Ps4 Pro with long blue light of death, visual inspection looks fine apart from dust and the very dried thermal paste which I cleaned and replaced, I scoped the board around for any shorts on capacitors and there were none, no blown fuses either. Looking under a thermal camera, southbridge gets warm along with APU and phases for the APU. I cannot tell if RAM is too cold? maybe not powered? but RAM chips are all the same temperatures. At this point I removed NOR and enabled UART to diagnose further. The only thing I get from UART is this following message:
          08-21-2023, 02:41 PM
        • protonusr22
          Sony 49XH9505 four flash of death
          by protonusr22
          I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
          The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
          Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
          Many thanks in advance,
          02-07-2024, 08:10 AM
        • stanwebber
          did bad capacitors kill my motherboard or prolonged exposure to faulty psu?
          by stanwebber
          i've got a pretty rare motherboard that i'm evaluating for repair. it's a biostar m7mia-raid which is the only ddr socket a motherboard ever produced, consumer or industrial, with an isa slot. its 20 years old now and finally gave up the ghost last month. i was saving a dd image of the hdd to a portable usb drive when i found it unresponsive with a black screen and a solid lit hdd led. after forcing it to power down it never posted again. the psu/cpu/case fans will spin and the onboard motherboard power led will light up, but no beeps or error codes even with the cmos reset and ram plus all expansion...
          03-10-2022, 12:35 AM
        • zwarder
          LG 42PJ350 panel death ?
          by zwarder
          Hi initially suspected Va & Vs being low but they do come back up to very near spec.
          The screen looks pixelated & blotchy any ideas?...
          08-17-2023, 03:47 AM
