Capacitor "Crackling"
  • technoducky
    • Dec 2010
    I have a Asus Power M5 which emits a "crackling" noise from the general CPU area, I think this might be the capacitors as nearly all of the system voltages are out by around 1.5 to 2 volts (it fried a USB memory stick), I have tested the PSU voltages and they are all fine, however there have been no system instabilities.
    Any help is greatly appreciated.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Capacitor "Crackling"
    Don't think it's the caps making that noise. Rather the inductors switching the CPU power. But it may be caused by bad caps indeed.
    A working TV? How boring!
    • c_hegge
      • Sep 2009
      • 5219
      I once fired up a pc and heard a crackling sound. It turned out that bubbles were coming out of one of the caps.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Capacitorial
        Powersupply has all the voltages - Monitor still no power
        by Capacitorial
        Hello guys,
        I have a Philips 240B7QPJEB. The monitor seems completely dead.
        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
        The weird thing is, that the Power LED is powered over the TCON board.
        On The TCON...
        12-28-2024, 02:12 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
