identifying smd capacitors
  • Cornboats
    Dave
    • Oct 2010
    • 232
    I've got a LG 6871QYH039A y-sus board on which there are some coupling capacitors that I wrecked removing the ipm.
    The good ones that I didn't wreck show 0 resistance/inductance/capacitance on my component annalyser.
    Anyone know how I go about replacing them?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: identifying smd capacitors
    Are you testing in or out of circuit?
    You'll most likely need to find a service manual with a parts list so you know what to buy.
    If you can't find one, post some photos of the thing. Someone may recognize the board and know what the components are.
    -David VanHorn
    • varkatope
      Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
      by varkatope
      Hey there, retro fans.
      I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
      12-15-2024, 09:48 AM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
      After all of...
      07-13-2024, 08:14 PM
    • Cama
      Solar Inverter - SMH-II - 2 missing capacitors
      by Cama
      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
      My model is : EASUN SMH-II 7 KW
      Mother Board : P/N 18947-002401250250
      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
      Thank you...
      09-12-2025, 02:50 AM
