GeForce 9600 GT Bad Caps
  • JBotts420
    • Dec 2010
    • 8
    Ok i have 3 bad caps, and have a 7 more that i want to know if i should replace them or not. I Found a thread that had 2 of the caps that are blown but not the 3rd one. The 3 on the right are the ones that need to be replaced, the others are the ones i have questions about if i need to replace them. If you need me to tell you what the top says just ask.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: GeForce 9600 GT Bad Caps
    Sacon FZ are frequent visitors here.
    [That's what those are.]
    Just do a search for 'Sacon FZ' and you have all sorts of reading material.
    Usually Panasonic FM is a good replacement but check the specs to be sure.
    Mann-Made Global Warming.
    - Dr Seuss
    • yyonline
      • Jul 2009
      • 692
      Replace the FZ caps. Aside from the FZ, I see Nichicon CF polymer, Sanyo polymer (purple), chemicon PS-A polymer (blue with A under a shield logo), and a Suncon electrolytic (black). All of these, with the exception of the FZ, are generally reliable and likely do not need to be replaced.
      FM is a good capacitor, but I'm not sure that its specs are good enough, and they tend to be larger than the original caps, which may lead to clearance issues.
      Badcaps.net sells replacements that will work to replace the FZ -
      To replace 6.3V 1500uF:
      https://www.badcaps.net/store/produc...products_id=40
      To replace 6.3V 1000uF:
      https://www.badcaps.net/store/produc...products_id=47 10V can be used in place of 6.3V, since the rated voltage is just a limit of what the capacitor can handle. Note that the Rubycon is 14mm high. If there is not sufficient clearance, Samxon GC can be used instead:
      https://www.badcaps.net/store/produc...products_id=70
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The FM specs are much better than the FZ on the 1500uF 6.3v.
        Thing is the FM are 8mm longer than the FZ.
        If short is needed then MBZ/MCZ are good.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You only need to replace the ones with FZ in the part number.
          I only see three in the photo.
          - Dr Seuss
          • JBotts420
            • Dec 2010
            • 8
            Yes there is only 3 FZ caps. Thank you all for the quick answers. Ive ordered the 3 caps, and will let ya know the outcome. Thank you again!
            • JBotts420
              • Dec 2010
              • 8
              Yay it works!!!!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Congrats!
                - Dr Seuss
                  NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                  The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                  10-02-2024, 08:52 AM
                  by momaka
                  03-12-2025, 03:42 PM
                  NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                  The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                  10-02-2024, 07:51 AM
                  NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                  The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                  10-01-2024, 01:54 PM
                  NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
                  The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
                  10-02-2024, 08:57 AM
