Do you got Evercon datasheets ?
Mann-Made Global Warming.
- Dr Seuss
Re: Do you got Evercon datasheets ?
I'm not seeing anything that makes sense as a cross reference.
They make caps to order so presumably who ever orders can have them marked with their own series code.
.Mann-Made Global Warming.
- Dr Seuss
Now that I've seen the picture....
That isn't an NK series.
E5NK is the date code.
That cap probably dates back to when GSC only had two series and they went by the sleeve color.
RE was Green.
LE was Black.
I think you have an LE there.
- Dr Seuss
The datasheets I got were from a WebArchive copy of http://www.gsc-cap.com/ from 2004 - does that seem old enough?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
PCBONEZ - You are the man!That cap probably dates back to when GSC only had two series and they went by the sleeve color.
RE was Green.
LE was Black.
I think you have an LE there.Comment
Just a trivia
GSC full name = GEN SALES ELECTRONIC CO., LTD
http://web.archive.org/web/200302050...sc-cap.com.tw/
- Dr Seuss
Yes.The datasheets I got were from a WebArchive copy of http://www.gsc-cap.com/ from 2004 - does that seem old enough?
They made the LE and RE series from sometime in the 90's until they went *poof* [or at least their site did] in 2005.
Both of them sometimes had the series marked and sometimes not. Had to go by the colors.
Then in '07 Evercon showed up at http://home.so-net.net.tw/gsccap/NEW/e-p1.htm.
It showed both Sacon and Evercon info for a while.
Then that site went *poof* in 2008 - just about the time the crap FZ series were getting famous.
.Last edited by PCBONEZ; 12-07-2010, 06:13 PM.Mann-Made Global Warming.
- Dr Seuss
Which archive were you able to access data sheets at?The datasheets I got were from a WebArchive copy of http://www.gsc-cap.com/ from 2004 - does that seem old enough?Mann-Made Global Warming.
- Dr Seuss
- Dr Seuss
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
Channel: General Capacitor Questions & Issues
by CdDvdFlashI've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
(Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...-
by Tomek188Hello,
I need datasheets for EN7521 and MT7520 (similiar chips). This is GPON ONT.-
Channel: Common Parts Library - Datasheets
01-17-2025, 01:47 PM -
by petehall347i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
by ten-dHi all!
I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...3 Photos-
- Loading...
