anything wrong with this?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: anything wrong with this?
    Nothing like laughing at a newb to make you feel better about yourself, eh guys? My thanks go out to the people who've made useful posts.
    we are a family here and you are welcome. we do like a few jokes but there is no flaming like on other forums. feel free to ask more questions so you can progress to a successful recap.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Back to dood's original idea, that is workable with components like axial lead, thru-hole diodes and resistors or even disc ceramic caps. With the swaging of the can, the foil and paper in the core, the electrolyte (very conductive!), and the rubber "bung" it would be somewhere between a mess and disastrous to try with lytic caps.
      A good, anti-static, Weller, Hakko, or Metcal (the MBZ of soldering irons) is in order, though not cheap. Be sure the tip touches the cap lead wire as well as the PCB pad, as this conducts the heat up the thru-hole better.
      PeteS in CA
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Well, I de-capped the motherboard using a 25w iron this morning. went fairly well... there were only two legs I couldn't get out of the hole, so I need to go find a pin or something to help them out. Here's a question, how do I know what was + and what was -? Each cap spot is marked, half colored white and the other half just natural. Is that a polarity marking? Also, one of the legs on each cap was soldered into a square on the back, the other was just a regular round hole.
        Also, anyone know how long it takes for caps to be delivered through this site?
        Ludicrous gibs!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yes it is polarity marking. the white is the - which is where you will put the striped side of the cap.
          however some manufacturers asus for instance have it the opposite way. also one some boards there may be a cap which is the wrong way around.
          this is why it is important to make a drawing of the polarity of the original caps on the board before you remove all the caps.
          what is the board you are recapping. maybe someone can make a drawing for you so you can cross check.
          please PM Topcat only he knows.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            I've also found that the white side corresponds to a gold strip down the one side of the cap. But nothing is actually marked + or -...
            Also, I sent Chris an email on Thursday or Friday (forget which) asking for a status update, as I haven't heard anything since I got the receipt for my paypal payment...
            Ludicrous gibs!
            • Chris1992
              • Apr 2005
              • 561
              #26
              the stripe is for negative side.
              The great capacitor showdown!
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
                by momaka
                03-12-2025, 03:42 PM
              • madscientist750
                Replacing electrolytic caps by solid caps on old motherboards
                by madscientist750
                I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                10-19-2025, 06:10 AM
                EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                by momaka
                I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                So, here is the...
                06-06-2020, 04:39 PM
